System.Net.Http.HttpRequestException: Error
  • System.Net.Http.HttpRequestException: Error
    Hi Spud,
    Getting the below error:
    Feb-15 18:27:42 IFTTT ERROR System.Net.Http.HttpRequestException: Error while copying content to a stream. ---> System.IO.IOException: Unable to read data from the transport connection: The connection was closed. at System.Net.ConnectStream.InternalWrite(Boolean async, Byte[] buffer, Int32 offset, Int32 size, AsyncCallback callback, Object state) at System.Net.ConnectStream.BeginWrite(Byte[] buffer, Int32 offset, Int32 size, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Net.Http.ByteArrayContent.SerializeToStreamAsync(Stre am stream, TransportContext context) at System.Net.Http.HttpContent.CopyToAsync(Stream stream, TransportContext context) --- End of inner exception stack trace --- at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at HSPI_IFTTT.FolderMonitoring.d__14.MoveNext()
    Not sure if it is a plugin error or something else. I turned on debug logging but cannot find the location of the file.
    Michael
    the logs are written in the HS logs (there is no file)
    how often do you get this error?
      I started getting the error again a couple times per day. Today I received 4 times.
      an-31 19:04:35 IFTTT ERROR System.Net.Http.HttpRequestException: Error while copying content to a stream. ---> System.IO.IOException: Unable to read data from the transport connection: The connection was closed. at System.Net.ConnectStream.InternalWrite(Boolean async, Byte[] buffer, Int32 offset, Int32 size, AsyncCallback callback, Object state) at System.Net.ConnectStream.BeginWrite(Byte[] buffer, Int32 offset, Int32 size, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Net.Http.ByteArrayContent.SerializeToStreamAsync(Stre am stream, TransportContext context) at System.Net.Http.HttpContent.CopyToAsync(Stream stream, TransportContext context) --- End of inner exception stack trace --- at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at HSPI_IFTTT.FolderMonitoring.d__14.MoveNext()
        I am now getting this once or twice per hour. I have turned off the plug in and then turned it back on, but I still get them. I'm running the .411 beta of HS3.
        Michael
