Question: Best way to set up triggers at several different times?
  • Question: Best way to set up triggers at several different times?
    I have been using HomeSeer virtual device triggers to change set points on my Trane (Nexia) thermostats. The virtual devices turn on at specific times of the day or when the security system is armed stay or armed away. I've written about this before: My applets usually run when they are supposed to. However, my IFTTT activity log has a multitude of "applet failed" at random times. So, I have decided to try Spud's plugin and I hope I won't see the huge list of "applet failed" with applets using this plugin. I got it installed and have set up an event to trigger at a specific time. It worked fine. Now, I want to set up the rest of the time triggers of 5:30 AM, 8:00 AM, etc.; as well as triggers of "armed away," "armed stay." Is it correct that I need to set up a different DropBox folder for each trigger or is there a different way to do this? Thanks. Elliott
    if your IFTTT action is always the same (i.e you only have one applet that turns on the thermostat) then you can have all your homeseer events writing to the same dropbox folder, otherwise you need different folders.
      Thank you.
