Is DropBox trigger working for anyone in IFTTT?
  • #16
    @Moskus, does it work now?
    • #17
      Aha, THERE that damn button is. I thought it was up to each individual event/action to implement it...
      Just ran, I'll report back in 15-20 minutes.
      EDIT: That did the trick! Now it works!
      • #18
        I posted version 3.0.1.3 here. With this version existing files in dropbox are not overwritten, instead if a "file.txt" already exist the new uploaded one will be renamed to "file (1).txt"
        This avoid to use the $time workaround explained above.
        • #19
          Having a similar problem with triggers not working (using Stringify, but also appears to not be working for IFTTT). Essentially, having an email trigger add a txt file into dropbox to activate a scene or device. The creation of the txt file appears to be working fine, but I am unable to get an event to activate. Manually moving a txt file into the folder in dropbox doesn't activate the event either. Attached is the debug info in the log and one of the events. Thoughts?
          Jan-28 2:06:19 PM IFTTT DEBUG path/not_found/.. for /stringify/disarmed
          Jan-28 2:06:18 PM IFTTT DEBUG path/not_found/ for /stringify/stay
          Jan-28 2:06:17 PM IFTTT DEBUG path/not_found/. for /stringify/away
          • #20
            where is located your Stringify folder in dropbox? are you sure there is no typo? Could you post a screenshot of your dropbox folder?
            I just tested this again on my system and it worked fine.
            • #21
              Attached. Only other thing I can think of that may be affecting it is that my dropbox folder location is on a different drive than default. Unless, of course, that I'm missing something easily fixable (which is entirely possible).
              • #22
                stay, away, disarmed need to be folders not txt files. Then the txt files need to be written by IFTTT in those subfolders
                • #23
                  Got it. I had read somewhere while setting this up that Stringify couldn't write to subfolders beyond the main folders in Dropbox (which ended up being incorrect - the subfolder can be included in the file name as shown). Working just fine now. Thanks for the help!
