[minor] IFTTT request timeouts after processing dropbox file(s)
    Hi Spud,
    I have a minor issue with IFTTT plugin. Every time a trigger starts a request timeout error occurs after 2 minutes. I don't see any issues but I wonder what can cause this error?
    Oct 19 11:00:27 hs3 mono[25890]: Oct-19 11:00:27 DEBUG New file found: /Private/IFTTT/Triggers/Weather/forecast-for-October 20, 2018.txt
    Oct 19 11:00:27 hs3 mono[25890]: 11:00:27:5728:[IFTTT]->DEBUG New file found: /Private/IFTTT/Triggers/Weather/forecast-for-October 20, 2018.tx
    Oct 19 11:00:28 hs3 mono[25890]: Oct-19 11:00:28 DEBUG Global variable ifttt_wu_TomorrowsCondition created
    Oct 19 11:00:28 hs3 mono[25890]: 11:00:28:1299:[IFTTT]->DEBUG Global variable ifttt_wu_TomorrowsCondition created
    Oct 19 11:00:28 hs3 mono[25890]: Oct-19 11:00:28 DEBUG Global variable ifttt_wu_TomorrowsHighTemp created
    Oct 19 11:00:28 hs3 mono[25890]: 11:00:28:1322:[IFTTT]->DEBUG Global variable ifttt_wu_TomorrowsHighTemp created
    Oct 19 11:00:28 hs3 mono[25890]: Oct-19 11:00:28 DEBUG Global variable ifttt_wu_TomorrowsLowTemp creat
    Oct 19 11:00:28 hs3 mono[25890]: 11:00:28:1345:[IFTTT]->DEBUG Global variable ifttt_wu_TomorrowsLowTemp created
    Oct 19 11:00:28 hs3 mono[25890]: Oct-19 11:00:28 DEBUG Global variable ifttt_wu_ForecastUrl created
    Oct 19 11:00:28 hs3 mono[25890]: 11:00:28:1366:[IFTTT]->DEBUG Global variable ifttt_wu_ForecastUrl created
    Oct 19 11:00:28 hs3 mono[25890]: Oct-19 11:00:28 DEBUG Global variable ifttt_wu_TomorrowLastUpdated created
    Oct 19 11:00:28 hs3 mono[25890]: 11:00:28:1393:[IFTTT]->DEBUG Global variable ifttt_wu_TomorrowLastUpdated created
    Oct 19 11:00:28 hs3 mono[25890]: Oct-19 11:00:28 DEBUG Deleting file /Private/IFTTT/Triggers/Weather/forecast-for-October 20, 2018.txt
    Oct 19 11:00:28 hs3 mono[25890]: 11:00:28:1424:[IFTTT]->DEBUG Deleting file /Private/IFTTT/Triggers/Weather/forecast-for-October 20,2018.txt
    Oct 19 11:00:28 hs3 mono[25890]: 11:00:28:1427:[Event]->Event Trigger "IFTTT triggers weather underground update trigger"
    Oct 19 11:00:28 hs3 mono[25890]: 11:00:28:1429:[Event]->Running script and waiting: /usr/local/HomeSeer/scripts/weather.vb("Main")
    .. approx 2 minutes later...
    Oct 19 11:02:08 hs3 mono[25890]: 11:02:08:1439:[IFTTT]->The request timed out
    hs3linux 478
    IFTTT 3.0.1.3
    Mono version 5.0.1.1 on debian version 9.5
    Zigmund
    When you get the "request timed out" error, do you have other log lines at the same time?
    It looks like it's HS3 and not the plugin that throws this error, so I'm not sure what request is timing out.
    Are the global variables correctly created ?
      Thanks Spud your remark about it's not the IFTTT plugin did help me to find the problem.
      The request timeout error was thrown by the weather.vb script triggered by the event, not the plugin.
      The script fetches the url used in one of the global variable, which was blocked by the firewall.
      Problem now solved, thank you.
