Echo/IFTTT/Dropbox/Homeseer/Event - use options?
  • Echo/IFTTT/Dropbox/Homeseer/Event - use options?
    flying by the seat of my pants with this..
    Have a recipe to create a file in /public/ifttt/actions/klon called kitchenlightson.txt
    IFTTT is tied into Alexa so I say Alexa, trigger kitchen lights on
    Alex passes this to IFTTT
    IFTTT creates the file in dropbox
    I have an event in homeseer called IFTTT Kitchen Lights On
    I have the IFTTT Trigger
    I have the IFTTT Action looking for the file in KLOn
    Then set the device <all my kitchen lights> on
    So it runs great, except it runs over and over and over until the file is gone.
    Is it normal to have to use options and tell the event Cannot Rerun For and use 30 seconds to allow time for the plugin to delete the file?
    Also ---
    I learned I have to have 1 folder for On (KLOn) and one folder for Off (KLOff) because if I don't the lights just go on and off even though there is a specifically named file in the Actions folder.
    I have HS3 with IFTTT 3.0.0.11
    No this is not normal, the plugin is supposed to delete the file immediately after the trigger is fired. I just tested it again here and it works for me.
    Could you set the log level to debug from the config page, then disable/enable the plugin, then trigger your event, and then paste the logs here?
    Also ---
    that's correct you need one folder for each different trigger, the plugin doesn't care for the file name.
      IFTTT Log
      This is with the "do not repeat for 30 second" still on.
      Log:
      May-07 21:45:44 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:45:44 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:45:44 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:45:44 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:45:44 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:45:44 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:45:44 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:45:43 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:45:43 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:45:24 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:45:24 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:45:24 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:45:24 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:45:23 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:45:23 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:45:23 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:45:23 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:45:22 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:45:05 Plug-In Finished initializing plug-in IFTTT
      May-07 21:45:05 IFTTT INFO Thread #13 started monitoring folder /public/ifttt/actions/klon
      May-07 21:45:05 IFTTT INFO Thread #12 started monitoring folder /public/ifttt/actions/kloff
      May-07 21:45:05 IFTTT INFO IFTTT version 3.0.0.11
      May-07 21:45:05 Info Plugin IFTTT has connected. IP:127.0.0.1:56049
      May-07 21:44:54 Plug-In Shutting down Plug-In: IFTTT
      Then I went in and removed the do not re-run: (I had to go in and disable the event to get it to stop turn the lights on and off)
      May-07 21:54:04 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:54:04 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:54:04 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:54:04 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:54:04 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:54:03 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:54:03 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:54:03 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:54:03 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:54:03 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:54:03 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:54:02 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:54:02 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:54:01 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:54:01 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:54:01 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:54:01 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:54:01 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:54:01 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:54:01 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:54:01 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:54:01 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:54:01 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:54:01 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:54:01 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:54:01 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:54:00 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:54:00 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:54:00 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:54:00 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:54:00 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:54:00 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:54:00 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:54:00 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:54:00 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:54:00 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:54:00 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:54:00 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:54:00 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:59 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:59 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:59 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:59 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:59 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:59 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:59 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:59 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:59 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:58 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:58 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:58 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:58 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:58 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:58 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:58 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:58 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:58 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:58 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:57 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:57 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:57 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:57 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:57 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:57 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:57 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:57 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:57 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:57 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:57 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:56 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:56 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:56 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:56 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:56 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:56 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:56 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:56 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:56 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:56 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:56 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:56 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:56 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:56 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:55 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:55 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:55 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:55 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:55 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:55 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:55 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:55 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:55 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:55 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:55 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:55 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:55 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:55 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:54 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:54 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:54 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:54 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:54 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:54 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:54 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:54 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:54 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:54 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:54 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:54 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:54 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:54 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:53 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:53 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:53 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:53 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:53 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:53 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:53 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:53 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:53 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:52 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:52 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:52 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:52 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:52 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:52 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:52 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:52 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:52 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:52 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:52 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:52 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:52 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:51 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:51 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:51 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:51 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:51 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:51 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:51 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:51 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:51 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:51 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:51 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:51 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:51 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:50 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:50 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:50 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:50 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:50 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:50 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:50 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:50 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:50 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:50 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:50 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:50 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:50 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:50 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:49 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:49 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:49 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:49 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:49 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:49 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:49 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:49 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:49 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:49 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:49 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:49 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:49 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:49 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:48 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:48 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:48 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:48 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:48 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:48 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:48 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:48 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:48 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:48 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:48 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:48 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:48 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:48 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:47 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:47 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:47 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:47 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:47 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:47 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:47 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:47 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:47 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:47 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:47 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:47 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:47 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:47 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:46 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:45 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:45 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:45 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:45 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:45 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:45 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:45 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:45 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:45 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:45 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:45 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:45 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:45 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:43 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:43 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:43 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:43 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:43 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:43 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:43 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:43 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:43 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:42 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:42 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:42 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:42 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:42 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:42 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:42 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:42 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:42 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:42 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:42 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:42 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:42 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:41 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:41 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:41 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:41 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:41 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:41 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:41 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:41 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:41 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:41 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:41 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:41 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:41 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:41 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:40 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:40 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:40 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:40 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:40 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:40 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:40 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:40 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:40 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:39 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:39 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:39 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:39 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:39 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:39 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:39 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:39 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:39 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:39 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:39 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:39 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:39 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:38 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:38 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:38 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:38 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:38 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:38 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:38 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:38 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:38 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:38 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:37 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:37 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:37 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:37 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:37 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:37 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:37 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:37 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:37 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:37 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:37 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:37 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:37 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:36 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:36 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:36 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:36 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:36 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:36 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:36 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:36 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:36 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:36 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:36 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:36 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:36 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:35 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:35 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:35 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:35 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:35 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:35 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:35 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:35 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:34 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:34 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:34 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:34 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:34 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:34 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:34 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:34 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:34 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:34 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:34 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:34 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:34 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:34 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:33 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:33 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:33 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:33 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:33 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:33 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:33 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:33 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:33 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:32 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:32 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:32 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:32 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:32 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:32 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:32 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:32 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:32 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:32 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:32 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:32 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:32 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:32 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:31 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:31 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:31 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:31 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:31 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:31 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:31 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:31 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:31 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:31 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:31 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:31 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:31 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:30 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:30 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:30 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:30 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:30 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:30 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:30 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:30 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:30 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:30 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:30 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:29 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:29 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:29 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:29 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:29 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:29 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:29 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:29 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:29 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:29 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:29 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:29 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:29 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:28 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:28 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:28 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:28 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:28 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:28 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:28 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:28 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:28 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:28 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:28 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:28 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:27 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:27 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:27 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:27 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:27 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:27 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:27 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:27 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:27 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:27 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:27 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:27 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:27 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:27 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:26 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:26 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:26 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:26 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:26 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:26 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:26 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:26 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:25 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
      May-07 21:53:25 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
      May-07 21:53:25 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:25 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
      May-07 21:53:25 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:25 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:25 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
      May-07 21:53:25 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
      May-07 21:53:25 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:25 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
      May-07 21:53:25 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:25 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:24 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:24 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:24 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:24 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:24 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:24 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:23 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:23 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:23 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:23 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:23 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:23 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:22 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:22 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:22 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:22 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:22 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:22 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:21 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:21 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:21 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:21 Z-Wave ApplicationCommandHandler from node 2 HANDLING: COMMAND_CLASS_SWITCH_MULTILEVEL_V2 Frame(7)=3
      May-07 21:53:21 Z-Wave Z-NET-FLOOR1: Sending to node 2 (UnSecured) CC=COMMAND_CLASS_SWITCH_MULTILEVEL_V2
      May-07 21:53:21 Z-Wave Polling device: Jasco Switch Multilevel Node 2
      May-07 21:53:21 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:20 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:20 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:20 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:20 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:20 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:20 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:19 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:19 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:18 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:18 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:18 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:18 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:18 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:18 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:17 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:17 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:17 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:17 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:17 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:17 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:16 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:16 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:16 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:16 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:16 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:16 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:15 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:15 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:15 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:15 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:15 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:15 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:14 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:14 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:14 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:14 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:14 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:14 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:13 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:13 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:12 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:12 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:12 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:12 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:12 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:11 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:11 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:11 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:11 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:11 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:11 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:10 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:10 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:10 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:10 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:10 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:10 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:09 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:09 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:09 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:09 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:09 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:09 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:08 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:08 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:08 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:08 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:08 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:08 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:06 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:06 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:06 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:06 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:06 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:06 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:05 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:05 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:05 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:05 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:05 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:05 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:04 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:04 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:04 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:04 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:04 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:04 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:03 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:03 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:03 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:03 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:03 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:03 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:02 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:02 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:02 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:02 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:02 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:02 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:01 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:01 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:01 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:01 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:01 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:01 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:53:00 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
      May-07 21:53:00 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
      May-07 21:53:00 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
      May-07 21:53:00 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:00 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
      May-07 21:53:00 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
      May-07 21:53:00 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
      May-07 21:53:00 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
      May-07 21:52:59 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
        what kind of recipe are you using on the IFTTT side? Is that possible that it keeps recreating the kitchenlightsoff.txt over and over again?
        I tested it and the txt file is immediately deleted for me, and there is nothing on your log saying that there may be a problem with the deletion of the file.
        Could you test by copying manually an empty kitchenlightsoff.txt file to your dropbox folder, and see if it is correctly deleted.
          Same. I turned off the option on both the off and on and created a txt and dropped it in the off. This shut the lights off and kept trying for ~90 seconds:
          (BTW - you cannot have an empty file. Dropbox gives an error is the file is empty and won't upload it)
          May-14 21:35:01 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:35:01 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
          May-14 21:35:00 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:35:00 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
          May-14 21:35:00 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
          May-14 21:35:00 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
          May-14 21:35:00 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:35:00 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
          May-14 21:33:19 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:33:19 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:33:19 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
          May-14 21:33:19 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
          May-14 21:33:19 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
          May-14 21:33:19 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
          May-14 21:33:18 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
          May-14 21:33:18 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 0
          May-14 21:33:18 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:33:18 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 0
          May-14 21:33:18 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:33:18 Device Control Device: 1 Kitchen KitchenCans02 to Off (0)
          May-14 21:33:18 Device Control Device: 1 Kitchen KitchenCans01 to Off (0)
          May-14 21:33:17 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights Off"
          May-14 21:33:17 IFTTT DEBUG New file kitchenlightsoff.txt found in /public/ifttt/actions/kloff/kitchenlightsoff.txt
          Then I dropped a lights on and here is the log. The file seem to be delete right away but the event kept going.
          May-14 21:26:33 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:33 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:33 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:33 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:33 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:33 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:32 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:32 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:32 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:32 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:32 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:31 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:31 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:31 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:31 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:31 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:31 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:30 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:30 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:30 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:30 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:30 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:29 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:29 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:29 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:29 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:29 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:29 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:28 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:28 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:28 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:28 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:28 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:28 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:27 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:27 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:27 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:27 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:27 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:26 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:26 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:26 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:26 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:26 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:26 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:25 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:25 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:25 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:25 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:25 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:25 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:24 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:24 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:24 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:24 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:24 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:24 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:23 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:23 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:23 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:23 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:23 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:23 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:22 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:22 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:22 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:22 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:22 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:22 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:21 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:21 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:21 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:21 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:21 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:21 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:20 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:20 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:20 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:20 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:20 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:20 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:19 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:19 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:19 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:19 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:19 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:19 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:18 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:18 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:18 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:18 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:18 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:18 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:17 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:17 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:17 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:17 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:17 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:17 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:16 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:16 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:16 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:16 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:16 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:16 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:15 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:15 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:15 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:15 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:15 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:15 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:14 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:14 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:14 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:14 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:14 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:14 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:13 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:13 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:13 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:13 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:13 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:13 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:12 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:12 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:12 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:12 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:12 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:12 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:11 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:11 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:11 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:11 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:11 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:11 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:10 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:10 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:10 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:10 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:10 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:10 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:09 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:09 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:09 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:09 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:09 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:09 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:08 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:08 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:08 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:08 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:08 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:07 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:07 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:07 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:07 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:07 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:07 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:06 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:06 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:06 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:06 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:06 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:06 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:05 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:05 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:05 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:05 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:05 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:05 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:04 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:03 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:03 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:03 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:03 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:03 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:03 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:02 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:02 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:02 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:02 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:02 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:02 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:01 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:01 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
          May-14 21:26:01 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:01 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
          May-14 21:26:01 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
          May-14 21:26:01 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
          May-14 21:26:00 Event Event Trigger "Kitchen Lights IFTTT Kitchen Lights On"
          May-14 21:26:00 IFTTT DEBUG New file kitchenlightson.txt found in /public/ifttt/actions/klon/kitchenlightson.txt
