Initiate IFTTT Action from Script
  • Initiate IFTTT Action from Script
    I've just started playing around with IFTTT and quickly figured out that this plug-in is much more flexible than the MyHS IFTTT route since it supports more than device on/off triggers. However, In some cases what I need to be able to do is run a script to work through some complex logic and then trigger an IFTTT Action based on the results. Is it possible to initiate an IFTTT Action from a script? I know I could always just create a bunch of manual events with IFTTT Actions and run the event from the script but I was hoping for something a little cleaner.
    Ken
    it's not possible with the current version of the plug-in, but I could easily add a scripting to function to wrrte a text file to your dropbox, i. e. what the plugin does to trigger an IFTTT action
      That would be great!
      Ken
        in version 3.0.1.0 available here I have added the following scripting function:
        bool RunIFTTTAction(string dropboxFolder, string dropboxFile)
        here is an example of a C# script to call this function:
        public object Main(object[] Parms)
            hs.PluginFunction("IFTTT", "", "RunIFTTTAction", new object[] { "/IFTTT/Actions/Test", "test.txt" });
            return 0;
        Note that this version of the plugin uses a new version of the Dropbox API so you will have to reauthorize your account to use it.
