My Phlocation does not connect apple ID anymore - Help
  • My Phlocation does not connect apple ID anymore - Help
    Hi,
    I just noticed that PHlocation plugin does not update with apple anymore.
    07.october.2018 time 1144 something happened (yes it tool me a while to notice)
    I just tried to reactive the account but get the follow error in log, any ideas?
    des-06 14.36.05 Info Plugin PHLocation has connected. IP:127.0.0.1:59489
    des-06 14.36.05 Starting Plug-In Initializing plugin PHLocation ...
    des-06 14.36.05 Starting Plug-In Plugin PHLocation started successfully in 2 milliseconds
    des-06 14.36.05 PHLocation (Startup) Begins at 02.36.05.739
    des-06 14.36.05 PHLocation (Startup) Plug-in version is: 3.0.1.125
    des-06 14.36.05 PHLocation (Startup) Detected OS is Windows version 6.2.9200.0
    des-06 14.36.05 PHLocation (Startup) Detected OS is x64
    des-06 14.36.05 PHLocation (Startup) System decimal separator used is [,]
    des-06 14.36.05 PHLocation (LoadPiSettings) HSAppPath = C:\Program Files (x86)\HomeSeer HS3
    des-06 14.36.05 PHLocation (LoadPiSettings) ConfigPath = C:\Program Files (x86)\HomeSeer HS3\Data\PHLocation\Config.phd
    des-06 14.36.05 PHLocation (LoadPiSettings) LogPath = html\PHLocation\Logs\
    des-06 14.36.05 PHLocation (LoadPiSettings) ImagePath = images\PHLocation\
    des-06 14.36.05 PHLocation (LoadPiSettings) MapPath = html\PHLocation\Maps\
    des-06 14.36.05 PHLocation (LoadPiSettings) DataPath = C:\Program Files (x86)\HomeSeer HS3\Data\PHLocation\PHLocation.phd
    des-06 14.36.05 PHLocation (LoadPiSettings) BinPath = C:\Program Files (x86)\HomeSeer HS3\Data\PHLocation\
    des-06 14.36.05 Starting Plug-In PHLocation loaded in 201 milliseconds
    des-06 14.36.05 Plug-In Finished initializing plug-in PHLocation
    des-06 14.36.06 PHLocation (LoadConfigSettings) Called.
    des-06 14.36.06 PHLocation (LoadConfigSettings) Logging of http requests to file is ON.
    des-06 14.36.06 PHLocation (LoadConfigSettings) iCloud max retries set to 6
    des-06 14.36.06 PHLocation (LoadConfigSettings) iCloud give up after 5 tries.
    des-06 14.36.06 PHLocation (LoadConfigSettings) iCloud retry time 5000 ms.
    des-06 14.36.06 PHLocation (LoadConfigSettings) Using stored iCloud client ID: 99523824-C7A2-4392-8582-837EE8570CDE
    des-06 14.36.06 PHLocation (LoadConfigSettings) UTC offset secs: 3600
    des-06 14.36.06 PHLocation (Startup) LoadIniSettings completed OK.
    des-06 14.36.06 PHLocation (LoadWebServerSettings) Called.
    des-06 14.36.06 PHLocation (Startup) LoadWebServerSettings completed OK.
    des-06 14.36.06 PHLocation (Startup) Existing installation detected. Running version update check.
    des-06 14.36.06 PHLocation (Startup) Database version is: 9
    des-06 14.36.06 PHLocation (Startup) Database structure update not required.
    des-06 14.36.06 PHLocation (Startup) Plug-In is licensed.
    des-06 14.36.06 PHLocation (CreateDeviceLists) iAccount type device PHLCIC[1196]R added to monitoring list.
    des-06 14.36.06 PHLocation (CreateDeviceLists) iAccount type device PHLCIC[37]R added to monitoring list.
    des-06 14.36.06 PHLocation (http) Server thread started OK on port 8085
    des-06 14.36.06 PHLocation (CreateDeviceLists) There are no active custom user devices. Setting monitoring to OFF.
    des-06 14.36.06 PHLocation (Startup) Update checking or DbPrune is on. Start UpdTimer.
    des-06 14.36.06 PHLocation (StartDQThreads) Pos DQ thread started OK.
    des-06 14.36.06 PHLocation (StartDQThreads) Fence DQ thread started OK.
    des-06 14.36.06 PHLocation (Startup) Active iCloud accounts found. Attempting to start iCloud services.
    des-06 14.36.06 PHLocation (StartiCloud) Called.
    des-06 14.36.06 PHLocation Error (StartiCloud) Start service error for index : 0 - System.IO.FileLoadException: Could not load file or assembly 'Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) File name: 'Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' at i.d..ctor(a A_0) at q.g() WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
    des-06 14.36.06 PHLocation Error (StartiCloud) Start service error for index : 1 - System.IO.FileLoadException: Could not load file or assembly 'Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) File name: 'Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' at i.d..ctor(a A_0) at q.g() WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
    des-06 14.45.54 PHLocation Warning (ResetiAccount) Stopping all iCloud services due to an iAccount reset.
    des-06 14.45.54 PHLocation (StopiCloud) Stopallservices called.
    des-06 14.45.54 PHLocation Warning (DeleteCfile) Stored login data deleted for iCloud device ref: 37 If 2FA is enabled on this account you will need to re-validate.
    des-06 14.45.54 PHLocation Warning (ResetiAccount) Re-Starting iCloud services following an iAccount reset.
    des-06 14.45.54 PHLocation (StartiCloud) Called.
    des-06 14.45.54 PHLocation Error (StartiCloud) Start service error for index : 0 - System.IO.FileLoadException: Could not load file or assembly 'Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) File name: 'Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' at i.d..ctor(a A_0) at q.g() WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
    des-06 14.45.54 PHLocation Error (StartiCloud) Start service error for index : 1 - System.IO.FileLoadException: Could not load file or assembly 'Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) File name: 'Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' at i.d..ctor(a A_0) at q.g() WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
    des-06 14.46.04 PHLocation Warning (ConfigDevice) Restarting iCloud services due to a config change!
    des-06 14.46.04 PHLocation (StopiCloud) Stopallservices called.
    des-06 14.46.05 PHLocation (CreateDeviceLists) iAccount type device PHLCIC[1196]R added to monitoring list.
    des-06 14.46.05 PHLocation (CreateDeviceLists) iAccount type device PHLCIC[37]R added to monitoring list.
    des-06 14.46.05 PHLocation (CreateDeviceLists) There are no active custom user devices. Setting monitoring to OFF.
    des-06 14.46.05 PHLocation (StartiCloud) Called.
    des-06 14.46.05 PHLocation Error (StartiCloud) Start service error for index : 0 - System.IO.FileLoadException: Could not load file or assembly 'Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) File name: 'Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' at i.d..ctor(a A_0) at q.g() WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
