Originally posted by MNB
View Post
PHLocation V2 Discussion
This is a sticky topic.
Originally posted by sparkman View Post
What user account did you configure within GF to authenticate to the HS server?Computer: CUK Intel NUC7i7BNH
Op System: Windows10 Pro - Work Station
HS Version: HS4 Pro Edition 4.2.6.0
Plug-Ins: BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLRoombaWifi 2.0.37.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.1,EasyTrigger 3.0.0.74,Harmony Hub 4.0.13.0,HSBuddy 3.25.614.1,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 3P 0.0.0.52,Random 3.0.0.2,Restart 1.0.0.7,rnbWeather 4.2.0.0,SDJ-Health 3.1.0.3,Sonos 3.1.0.59,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.14.0,Z-Wave 3.0.7.0,Z-Wave UI 1.0.0.0, and Jon00 scripts.
Originally posted by rprade View PostYou are mixing two different method. If you use MyHS, you do not control the user, HomeSeer does through the MyHS communication protocol. Unless I missed something MyHS always gives admin access.
Sent from my iPad using TapatalkHS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
Originally posted by rprade View PostThere is no issue with authentication. PHL2 does not log normal communications, only errors and warnings. When a GeoFency post is normal, it is not an error and is not logged. Debug logging is now sent to a file, when selected.
I thought Paul was going to do release today, was waiting to download and plugin. MikeComputer: CUK Intel NUC7i7BNH
Originally posted by The Profit View Post
In my MyHS service, I can select “Manage” instead of “Access” and then setup users. For each user I can select which hometroller they have access to, then on the hometroller I setup each users access level. Based on the other posts here, I assume that I should setup an HS user with Guest access rights for Geofency so that even if someone were to grab the user name and password that it would only be for guess access rights?
At login I can choose between Access and Manage
In Manage, I have these choices.
Originally posted by rprade View PostDo you have MyHS premium? I do not have those choices.
Plugin's:
Originally posted by rprade View PostNow, going back to this. How would someone "grab the user name and password"?
Because of my limited knowledge with gateways, I’m a little fearful that I’m going to make myself vulnerable.
So at the moment, I have setup a user in MyHS and also in HS with guest access and Geofency URL is the MyHS link that you posted earlier. I assume there is no way for someone to grab the user name and password with the MyHS link as it is encrypted, correct?
Plugin's:
I have no idea, I’m trying to figure out how to best setup Geofency so that I don’t get these log entries where someone is trying to hack into my system. I used to use the ddns option (Port 5???) and luckily didn’t notice any issues but once I started forwarding port 80 using the same ddns service, I started getting IP’s blocked in the HS log.
As far as I can tell MyHS is very secure. It is not super secret, top secret, no one can access secure, but it is reasonably secure and you should not get those log messages when using only MyHS for access.
Originally posted by rprade View PostIf you only use MyHS for accessing your system and don't expose it to the internet through a forwarded open port, you shouldn't get those log entries. I never do. Why do you have an external port forwarded to the IP and port of your HS server?
Originally posted by rprade View PostFor those of you posting from 3rd party apps like GeoFency, PHL2 does not use its own web server, it uses the HS built-in server. The posting is still the same as before with two changes 1) it now uses your HomeSeer web server port (usually 80) so create your port forwarding rules and structure the URL accordingly.HS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
I have the eternal port forwarded to the IP and port of my HS server because I thought I had correctly followed the directions in your above post, guessing that I must have misunderstood....Code:https://connected.homeseer.com/phl2api?dtype=GF
If you are using DDNS and port forwarding, you will want to use credentials you have created on your HS server. You would want to give that user the minimum rights, because communication is unencrypted. Depending on how your router is configured (NAT loopback or hairpinning), it may not work locally. Most consumer routers support NAT loopback, but it is not guaranteed. A Ubiquiti USG has it enabled by default, my pfSense did not.
The rules are different if you are able to run your server securely or if you use a VPN. It is a matrix of options. Each has its advantages and disadvantages.
To over simplify, when you post through MyHS, your HS server treats it as a local connection where https://connected.homeseer.com is functionally equivalent to the local IP of your hS system, once authenticated through the MyHS server.
Originally posted by sooty View Post
Correct. The message panel is not there in V2.
I can add it if required.
Paul..
Sent from my iPhone using Tapatalk_______________________________________________
HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
I just installed and not sure of the server URL I used to use connected11 or connected22. Is it now just connected.homeseer.com/PHL2API?dtype=BK
At first I got an update failed, but now I don't even get a notification on the phone. Note that this is a different phone than the one I use for PHL1
