Thanxs Randy I will make the necessary tweeking it the hope of resolving this issue. Would weak phone signal strength (2 Bars) be contributor? Mike
PHLocation V2 Discussion
This is a sticky topic.
Computer: CUK Intel NUC7i7BNH
Op System: Windows10 Pro - Work Station
HS Version: HS4 Pro Edition 4.2.16.0
Plug-Ins: AmbientWeather 3.0.1.9,APCUPSD 3.3.2.3,BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLRoombaWifi 2.0.37.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.2,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,iRobot 5.22.41.1,JowiHue 4.0.8.4,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 4.0.10.0,Random 3.0.0.2,Restart 1.0.0.7,rnbWeather 4.4.0.0,SDJ-Health 3.1.1.2,Sonos 3.1.0.59,Sonos4 4.0.1.12,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.31.0,Z-Wave 3.0.10.0,Z-Wave Parameters 4.0.55.0,Z-Wave UI 1.0.0.0, and Jon00 scripts.
Originally posted by MNB View PostThanxs Randy I will make the necessary tweeking it the hope of resolving this issue. Would weak phone signal strength (2 Bars) be contributor? Mike
HS4 Pro, Windows 10 pro
Originally posted by MNB View PostJohn, thanxs for explanation. I think part of the issue is related to Geofency app I noticed that both my home and inner Perimeter had the same "Monitoring Radius" 100 under the settings, both were set for 100 meter or ~328 feet. I've updated to move my inner Perimeter to 200 meters in the hope that might help, we'll see. Mike
Paul, I see that you've indicated that v 3.0.0.42 Jan 15th 2019 is available but the file is v.41 can you verify and update, thanxs MikeComputer: CUK Intel NUC7i7BNH
Good evening, I installed PHLOCATION2 and I have a small problem with the reverse address
Accented characters are not displayed correctly:
Rue Saint-Ouen, Morville-sur-Andelle, Dieppe, Seine-Maritime, Normandie, France métropolitaine, 76780, France
can you look?
The town is not resersed also:
Thank you
Jean-Francois
OK, after some checking, I think I had the wrong POST code. Changed from 202 to 200 and I get a message "Backitude Success!" I have the correct REF ID for the root of the user I created but none of the fields gets populated.
Do I need to get a new Google API or can I copy the ones I have from PH1?
Originally posted by racerfern View PostPaid? I've never doled out a dollar for an API key. I was given one by Google, don't remember how long ago and it works in PH1, so I copied it to PH2.
https://developers.google.com/maps/d...ed/get-api-keyHS4 Pro, Windows 10 pro
I have setup an iCloud account. I have the 3 devices. The polling interval device is set to 3 minutes. It never actually polls the iCloud account. I need to poll manually with the poll button on the account status device.
Do I need to setup a recurring event in order to get polling to automatically work?
Jim
Originally posted by AutomatedJim View PostI have setup an iCloud account. I have the 3 devices. The polling interval device is set to 3 minutes. It never actually polls the iCloud account. I need to poll manually with the poll button on the account status device.
JimHS4 Pro, Windows 10 pro
Guest
Just to let you know sooty the zip file is named .41 . In the updater overdride it is .42
I change the name of the .41 zipfile to .42...
but now I have .41 installed in homeseer plugin page
Code:FILEVERSION 3,0,0,41 PRODUCTVERSION 3,0,0,41 FILEFLAGSMASK 0x3F FILEFLAGS 0x0 FILEOS VOS_UNKNOWN | VOS__WINDOWS32 FILETYPE VFT_APP FILESUBTYPE 0x0 { BLOCK "VarFileInfo" { VALUE "Translation", 0x0, 1200 } BLOCK "StringFileInfo" { BLOCK "000004b0" { VALUE "Comments", "PH Location Plug-In for HS3" VALUE "CompanyName", "Paul Huddlestone" VALUE "FileDescription", "HSPI_PHLocation2" VALUE "FileVersion", "3.0.0.41" VALUE "InternalName", "HSPI_PHLocation2.exe" VALUE "LegalCopyright", "Copyright © Paul Huddlestone 2019" VALUE "LegalTrademarks", "" VALUE "OriginalFilename", "HSPI_PHLocation2.exe" VALUE "ProductName", "HSPI_PHLocation2" VALUE "ProductVersion", "3.0.0.41" VALUE "Assembly Version", "3.0.0.41" } } }
Originally posted by racerfern View PostSo using Backitude I need to use the latitude and longitude values to make my own geofences in events, is that correct? Until now I had been using the postal code string as a rough location but in my interest to put PHL2 to good use, it seems lat/lon seems the way to go.
- Likes 1
