Originally posted by rprade
View Post
PHLocation V2 Discussion
This is a sticky topic.
I'm using Backitude with location steals on my phone which works great, except for the altitude. I noticed that Backitude is sending the wrong altitude over to PHLocation 2. My GPS app on my phone shows an altitude of 100 feet, but Backitude would show an altitude of 25 feet. This would then reflect in PHLocation 2.
There is an option in Backitude to disable reporting of altitude data by removing the request parameter key for Altitude which prevents sending this over to PHLocation 2. (No key value - Request will not contain this field). When I do this, I'm not getting any altitude updates in PHLocation 2.
How is the elevation data utilized in PHL2? Is there any way to utilize the elevation data to calculate the altitude from the lat/lon if no data is received from Backitude? I have a google and mapquest api entered and elevation data is configured to use these sources, but the altitude is never updated.
Originally posted by AutomatedJim View Post
Definitely not updating. It is showing my last location with a timestamp where I was last night when I manually pressed the poll button.
Find my iPhone wasn’t working which tells me it wasn’t PHL2. We have a constant connect VPN and her iPhone was not updating. Mine was.
Michael
Originally posted by Rvtravlr View Post
This happened to us today on my wife’s account. The solution for us was to stop the app, double click home button and swipe up, verify that cellular data was on along with roaming, and then a soft reboot of the iPhone.
Originally posted by slbuck View PostI'll post back the event once I've had a few days to play around with it.
Hi Guys,
I have got PHLocation2 installed and working. so far so good.
I have my minimum distance to move set to 1km on my icloud. However when im walking around the site at work my time at location drops to 0m (site would be lucky to be 500m).
Should having this set to 1km stop this from happening? i think that how i did it in PHL1.
thanks
Originally posted by MattLau View PostJust to let you know sooty the zip file is named .41 . In the updater overdride it is .42
I change the name of the .41 zipfile to .42...
but now I have .41 installed in homeseer plugin page
Code:FILEVERSION 3,0,0,41 PRODUCTVERSION 3,0,0,41 FILEFLAGSMASK 0x3F FILEFLAGS 0x0 FILEOS VOS_UNKNOWN | VOS__WINDOWS32 FILETYPE VFT_APP FILESUBTYPE 0x0 { BLOCK "VarFileInfo" { VALUE "Translation", 0x0, 1200 } BLOCK "StringFileInfo" { BLOCK "000004b0" { VALUE "Comments", "PH Location Plug-In for HS3" VALUE "CompanyName", "Paul Huddlestone" VALUE "FileDescription", "HSPI_PHLocation2" VALUE "FileVersion", "3.0.0.41" VALUE "InternalName", "HSPI_PHLocation2.exe" VALUE "LegalCopyright", "Copyright © Paul Huddlestone 2019" VALUE "LegalTrademarks", "" VALUE "OriginalFilename", "HSPI_PHLocation2.exe" VALUE "ProductName", "HSPI_PHLocation2" VALUE "ProductVersion", "3.0.0.41" VALUE "Assembly Version", "3.0.0.41" } } }
Paul..
- 1 like
Originally posted by slbuck View PostI'm using Backitude with location steals on my phone which works great, except for the altitude. I noticed that Backitude is sending the wrong altitude over to PHLocation 2. My GPS app on my phone shows an altitude of 100 feet, but Backitude would show an altitude of 25 feet. This would then reflect in PHLocation 2.
If you remove the altitude parameter from the Backitude app so it doesn't send a value, then assuming you have a primary elevation provider set on the plug-in config>API's page it will attempt to obtain the data from the lat / lon.
Paul..
Hi, sooty rprade
i have seen a little problem in Reverse Geocode Data Provider,
Most of the times it does not show the street numbers at all..
Im here in the netherlands and dit test it but no numbers.
Also is it possible to show it like this [street] [number] [postalcode] [town] at the adress device because now its here all messed up.
I did use all providers(except google) because im out of api requestall the time.
The second issue is that after a plugin restart (Force update of position devices) gets unchecked again.
I would also do a request to add a number device, that shows the current home number where you are at.
regardsPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
Originally posted by bdraper View PostUsing Life 360, I have setup my service account but do not have the Life360 menu selection under User/Devices. I suspect this is due to the log message below.
Right now I am getting this in the log for Life360
Jan-12 17:07:07 PHLocation2 Error (PollAccount) LF Error in GetCircles. Jan-12 17:07:07 PHLocation2 Error (GetCircles) Auth failed for RootRef: 4213 exiting Sub.
I have verified the service account setup and actually logged into the Life360 website from my HomeSeer box, any ideas?Originally posted by rprade View PostI'll have to defer to Paul. Mine connected first try and all the users were there. So I know it can work.
I have always logged into the Life360 website with my phone number and password. However this did not work for setting up the Life360 service account with PHLocation2. Once I changed from cell number to using the email address, all went well.
Sorry for any confusion.
Billy Draper
I Paul,
after another install, the plugin is still in v .41.
Sometimes the HS3 plug-ins interface does not show the correct version until HS3 is re-started.
Go to Plug-Ins>PHLocation2>Configuration and it should show the correct version.
Paul..
regards
The plug-in does not make any changes to the order of the address data it receives from the 3rd party service although it may be possible to allow this to be user configurable.
Paul..
Originally posted by sooty View Post
Where did you read the version number?
Paul..
edit: logs show the update successful
another edit: after unzipping the update package, looking at the details of hspi_phlocation2. exe shows product version of 3.0.0.41.
