PHLocation V2 Discussion
This is a sticky topic.
    Originally posted by sooty View Post
    Can you email me some specific examples of coordinates that don't provide the data you are expecting.
    The plug-in does not make any changes to the order of the address data it receives from the 3rd party service although it may be possible to allow this to be user configurable.
    Paul..
    sooty Mail sended.
    rprade ok i understand now thanks for the reply
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
      Has anyone tried using PHLocation2 with a traccar server? And anyone tried using a Freematics ODB II dongle to track their car? Both of these are open source projects and work together. They seem ideal for integration with a DIY home automation platform like Homeseer.
      Also, does the PHLocation2 traccar device expect to be reaching out to a traccar server or receive data updates directly from a traccar client?
      Sent from my SM-N950U using Tapatalk
        Originally posted by keithj69 View Post
        I just downloaded the latest *42 beta and after an install and reboot of the system, I still see 3.0.0.41 (Beta) under general settings for ph2.
        edit: logs show the update successful
        another edit: after unzipping the update package, looking at the details of hspi_phlocation2. exe shows product version of 3.0.0.41.
        Sorry I thought I had fixed the download.
        I have just re-uploaded .42 which should now all be in order.
        Paul..
          All better now. Showing the correct version.
            Sorry, where is the link to download this new version?
            Plugin's:
              Do I have to write an event to create a map? There is a map viewer tab but I don't see anything, as opposed to PH1 which gave me maps. I think I missed a class.
                In the PHL2 Release Notes post in this forum here.
                  Paul..
                  . Running .42 now . Thank you Paul
                    Just like PHL, you can configure a map on each position root device on the PHLocation2 tab. The option for static maps is not currently there, but Paul said he may restore it.
                      OK thanks, I'll double check my settings. BTW, is your default path based on root, the HS3 folder or something else?
                        If you are referring to maps, they are in HomeSeer HS3/html/PHLocation2/Maps by default, but you can configure any local path you wish. The default name is 1234_current where 1234 is the RefID of the root device.
                          Randy where did you get the neat Trip Icons used in your map examples?
                          Computer: CUK Intel NUC7i7BNH
                          Op System: Windows 10 Pro - Work Station
                          HS Version: HS3 Pro Edition 3.0.0.435
                          Plug-Ins: BLBackup, BLGData, BLRoombaWifi, Device History, EasyTrigger, ImperiHome, Nest, PHLocation, Pushover 3P, Restart, Sonos, UltraCID3, UltraWeatherWU3, Z-Wave, and Jon00 scripts.
                            The only icons I use are supplied with the plug-in. You can choose round or square in 8 different colors and choose any letter or no letter for each configuration. Whatever you select for the device will be used on Event generated maps.
                              Thank-you sir, I'm learning something new every day... I thought your recent example looked nicer than the canned square icons. Mike
                                Here I have switched to MapQuest as a provider. It opens showing the full route. I messed with some of the coordinates to mask my home, but you can drill down and look individual locations and see the tool tips for each marker. Click on this link. Click on the green circles to zoom in and break up the clusters. There are actually 38 points on the map from a short trip I made today. Hover over the clusters for an idea of the area they cover.
