Originally posted by MNB
View Post
PHLocation V2 Discussion
This is a sticky topic.
Originally posted by rprade View PostI'm confused. Post #254 was from Fernando, so I cannot see the Event to which you are referring. Regardless, GeoFency does not have a service account, nor is it at all related to iCloud, so it doesn't have "users"HS 3.0.0.548: 1990 Devices 1172 Events
Originally posted by Spudjr View PostWhat is a recommended polling time for an Icloud account. Is there a daily limit. Is bandwidth a concern. Thanks
Originally posted by racerfern View PostI'm still only seeing the current point as opposed to a series of points. When I was at my office, it just showed me at the office. Now that I'm home it just shows me at home.
With a simple event I do get a bread crumb trail but unsure why there are so few points. I have BK set at 15 minutes. I assure you it takes longer than 15 minutes to go anywhere in this area. This is a map from a few days ago just before I disabled and removed PHL1.
I've been home all day with only a short trip to get lunch for my wife. I have 18 points in the database and a map showing 19 points. There is always one extra point in the history map, because it looks at the last location previous to the time period as the starting point.
Here is my history
Here is my map
Yesterday I drove twice to a place about 8 miles away and there were 133 points
I have a monitored position device using my cars latitude and longitude. It seems to be working fine regarding location and distance and all the other sub devices that are produced. However, should there be a location device under my monitored position device as there are under Geofency? For instance, when I get home under geofency the home device is inside. However, when I get home with my car there is no corresponding home device. Does that make sense? What I am looking for is the redundancy that was there with V1. Shouldn't it be the if Geofency becomes inside home or the car becomes inside home that a global home location device would be inside?
The history map is generated form the database. That will be determined by the minimum distance to move setting as well as the polling rate. What does your DB history look like?
You get lunch, you don't make lunch?
I found a db3 file called phlocation2.db3 but not readable. Where am I looking for a history database please?
The history viewer is on the dropdown from PHL2.
Then select the user, end date, end time and duration.
Originally posted by MNB View PostStephen, looking at your event you have a phone field "Phone Home Direction" and "Drive Time to Home" are these a iPhone field or other phone type or something else?
Hi,
i don't know if this has something to do with the plugin but everytime when it updates every 10 minutes it does change from home to an other location and then back.
but the strange thing its always 1400 meter and it writes it down in history... i really dont know why, when it updates again after it it goes normal.
// im using an iphone*
2019-01-19 15:39:23 50.******** 6******* 65 m Ka, Ke, ***XN NL Details 2019-01-19 15:39:18 50.******** 6******* 1414 m 61 Kwi, Ke, ***XG NL Details 2019-01-19 10:29:11 50.******** 6******* 65 m Ka, Ke, ***XN NL Details 2019-01-19 10:29:06 50.******** 6******* 1414 m 61 Kwi, Ke, ***XG NL Details 2019-01-19 09:59:10 50.******** 6******* 65 m Ka, Ke, ***XN NL Details 2019-01-19 09:59:05 50.******** 6******* 1414 m 61 Kwi, Ke, ***XG NL Details 2019-01-19 08:39:08 50.******** 6******* 65 m Ka, Ke, ***XN NL Details
RegardsPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
Originally posted by sparkman View Post
I see post 254 as Mike's as well. It's this one: https://forums.homeseer.com/forum/te...82#post1276982 and he's using Tasker, not Geofency.
Posts are not deleted, they are “soft deleted”. Moderators can view or restore a soft deleted post.
// im using an iphone*Regards2019-01-19 15:39:23 50.******** 6******* 65 m Ka, Ke, ***XN NL Details 2019-01-19 15:39:18 50.******** 6******* 1414 m 61 Kwi, Ke, ***XG NL Details 2019-01-19 10:29:11 50.******** 6******* 65 m Ka, Ke, ***XN NL Details 2019-01-19 10:29:06 50.******** 6******* 1414 m 61 Kwi, Ke, ***XG NL Details 2019-01-19 09:59:10 50.******** 6******* 65 m Ka, Ke, ***XN NL Details 2019-01-19 09:59:05 50.******** 6******* 1414 m 61 Kwi, Ke, ***XG NL Details 2019-01-19 08:39:08 50.******** 6******* 65 m Ka, Ke, ***XN NL Details
I don’t understand why you are getting two reports at each poll.
Regards
Regards
I won't try to explain the whole boring procedure of polling an iCloud account here but when an account is polled it returns data for all devices on that account. If any device has incomplete data, the plug-in will not process any location updates and will re poll the account after 5 seconds. This continues for up to 6 times before it aborts the poll and waits for the next interval.
There are some situations where it will let updates through even if something is incomplete and this may be the cause of your issue.
I'll check the code later this evening but what appears to be happening in your case is that it is letting the low accuracy update through then re-polling and letting another high accuracy update through.
If you put both of the actual coordinates from these 2 entries into Google maps, what is the distance between them?2019-01-19 10:29:11 50.******** 6******* 65 m Ka, Ke, ***XN NL Details 2019-01-19 10:29:06 50.******** 6******* 1414 m 61 Kwi, Ke, ***XG NL Details
What setting do you have on the Root User device in "Minimum distance to move" ?
Paul..
