Trying to change the polling time based on the time of day. I.E. reduce the polling time from 1 min to 60 minutes after 7:00 pm then increase it after 7:00 A.M. back to every minute. I'm sure it can be done but havent figure it out. Been playing with different stuff with 2 events but so far not successful. Any pointers from the experts. Thanks
PHLocation V2 Discussion
This is a sticky topic.
Originally posted by Skinnez View PostJust installed this last night. Excellent work as always. One question I have, are the database files the same format, I have a lot of years worth of data I would like to move over?
Cheers
J
Paul..
Originally posted by sooty View Post
The db format is different in V2, but I can look into putting together a script to convert and move it over.
Paul..
Cheers
J
Originally posted by rprade View PostI was just reviewing Paul's first draft of the operator's guide and one thing occurred to me. On the iCloud account management page if you have "Ignore Unknown Devices" checked, it may not present the option to add new devices. While that is not the way I thought it would work, I have never tested to see. Mine still offers me the ability to add a new user/device with that box checked.
From the manual;
DO NOT enable this option until you have added all the User devices that you want included in the plug-in as this option will prevent new devices being discovered.
A single iCloud account may have many devices registered to it but you may only want to monitor some of them in the plug-in. Once all required devices have been added, enabling this option allows the plug-in to ignore the state of the non-included devices which speeds up the polling process considerably for accounts with multiple devices where only some of those devices are included in the plug-in.
Paul indeed pointed me to this option. I had it set in the old version and just copied it over while setting the icloud options. Disabling the option immediatly enabled picking a device for me. But as you described my ipad is still in the list, also on the old version. But if I understood Paul correctly, it will no longer scan its position and other (new) devices will not be added to this list, nor scanned for position?
Wim-- Wim
Randy,
Wim
When a device is selected from the list and the Save Changes button is clicked, that device will be removed from the (Heard List) and added to the (Known List).
With (Ignore Unknown Devices) ON, any devices returned in the poll that are NOT in the (Known List) will be ignored.
The (Heard List) is only cleared at plug-in start-up so, even with (Ignore Unknown Devices) ON, devices will remain in the list until either they are added as iDevices or the plug-in is re-started.
To try and explain how the polling of an iCloud account works.
1. The plug-in logs into your your iCloud account and asks for information. This is done at ACCOUNT level NOT at DEVICE level.
2. iCloud reaches out to each device registered on the account to get up to date information from that device.
3. iCloud returns information for ALL devices registered to the account back to the plug-in.
The returned information contains lots of data which includes device related data like battery level, charging state etc in addition to location information.
4. The plug-in processes the data for each device.
Given the above above sequence of events:
If for example the user has an iMac on their account that spends much of it's time switched off and never moves from the office, then when iCloud reaches out to that device (stage 2 above) and it is switched OFF it will return an "Off-Line" status and depending if location services are enabled on that device may return nothing for the location or data that is outdated.
When iCloud reaches out (stage 2 above) to say an iPhone, even if the iPhone is ON and connected to the internet, it can take some time for it to respond with the latest info. e.g. it is trying to get a location fix. It may also be temporarily disconnected from the internet for some reason so could return an Off-Line status.
When the plug-in processes the returned data (stage 4 above) and sees that a device is Off-Line or has "Outdated Location Data" then this could just be because the device is still obtaining a location fix or just wasn't reachable at the time iCloud requested info from it.
I won't go into all the details here but the plug-in uses various logic based on the returned data to decide if to re-poll the account. It will re-poll up to 6 times if necessary within a single polling interval before giving up and waiting for the next polling interval.
So, onto the point:
When the (Ignore Unknown Devices) option is ON, it won't use data from any devices that are not in the (Known List) to decide if to re-poll.
This significantly speeds up the polling process on accounts that have multiple devices when some of those devices are not required in the plug-in.
In cases when there are devices that are frequently unreachable (e.g. iMac that is switched off 90% of the time) then if these are not included in the plug-in and (Ignore Unknown Devices) option is ON then it will also improve battery life on the remaining devices as they don't have to be constantly re-polled because some other device on the account isn't responding.
Paul..
Randy,
Wim
HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
I installed .49 and went straight for the user guide. Thank you! Now, is there any advantage to using both Geofence and Tracking? I'm lost here because there are three
places to enter the connected2 URL in a EGZ server profile.
1. URL FHEM Geofancy
or
2.URL zone entered
URL zone exited
then further down there is
3. URL zone for tracking
Do I put the first one in FHEM and the second one in spot #3 OR do I create another server profile>
https://connected2.homeseer.com/phl2api?dtype=EG&
https://connected2.homeseer.com/phl2api?dtype=ET&androidid=${androidId}&lat=${realLatitude}&lon=${realLongitu de}&acc=${accuracy}&date=${localLocationDate}&phlid=1234
Originally posted by racerfern View PostI installed .49 and went straight for the user guide. Thank you! Now, is there any advantage to using both Geofence and Tracking? I'm lost here because there are three
or
2.URL zone entered
URL zone exited
The url ending in EG& goes in FHEM and the longer one goes in URL for tracking.
The ones for zone entry / exit are not needed with the plug-in but can be used when a different url needs to be called for each transition type.
Paul..
Originally posted by racerfern View Post.....Is there any advantage to using both Geofence and Tracking?
- Likes 1
Originally posted by Ltek View PostQuestions...
V2 removed Walking/Driving Distance... Why? I thought driving distance was useful.
Will you be posting in the HS3 Updater? Would make it so much easier for users to install/update.
thx for the fantastic work.
