If you do it from your browser, you are not sending any data, so it will of course be an error. The application on your phone sends a packet of data to the URL. Do the HS PHL2 fence devices update from your phone? You will not see log entries if it is successful, unless you have debug logging enabled, or if there is no properly configured PHL GF root device.
PHLocation V2 Discussion
This is a sticky topic.
Did you capture the Device ID and add it to the root?
If you haven't done that a successful post should generate a log entry.
One thing that sticks out is your URL
http://192.168.0.xx:XXXX/phl2api?dtype=GF
What port is HS running on? I'm thinking you are using the port of the PHL1 web server.
Originally posted by rprade View PostI forgot about the old URL for PHL1. The new API is just phl2api?dtype=GF, no matter how you post, because it uses the HomeSeer web server.
How are you posting? Through MyHS, port forwarding or a VPN? The MyHs credentials are used with MyHS, local admin credentials would be used for port forwarding or VPN. I do not need credentials for VPN, because it appears as a local connection and I have "No Password Required for Local/Same Network Login (Web Browser/HSTouch)" enabled. In this case it doesn't matter what credentials are used, but I put in my local admin credentials.
If your old was Notify on Entry and Exit - http://mnb.XXX.XXX:80XX/phlgeofency
The new would be Notify on Entry and Exit - http://mnb.XXX.XXX:80/phl2api?dtype=GF
What I don't know is if the 80XX was the port number of the old PHL web server. If your HS web server uses the default HTTP port (80) it can be omitted, if using VPN.
Port forwarding would require using your external port.HS 4.2.8.0: 2134 Devices 1252 Events
Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
Originally posted by MNB View PostOk, I first entered you suggestion using my local lan;
http://192.168.0.XX:XXXX/phl2api?dtype=GF within my GeoFency app and performed Test connection Entry/Exit and got "Successful ["CTime", "1/11/2019 5:04:10 PM"] message for both Entry/Exit, however whilst looking at my HS3 Log I did not see any entry.
Jan-11 3:16:10 PMPHLocation2 Warning(ProcessFenceUpdate) Fence data received from unknown device ID [V-W-X-Y-Z]!
device ID has been obfuscated.HS 4.2.8.0: 2134 Devices 1252 Events
Originally posted by sparkman View Post
I guess this makes it hard to run things in parallel. I could create duplicate fences withing Geofency, but that's probably more work than I want to go through. It will be easier to edit them to change the URL, build the new devices in HS and then update my events.
I just tried it here and get the following in my log with the Entry/Exit tests:
Geofency Device ID
All Geofence based user devices are added the same way and require the DeviceID from the mobile app.
Set up and configure the relevant app on your mobile device. Once this has been done and an upload attempt has been made from the mobile app, an orange warning entry will be written to the Homeseer log explaining that incoming data could not be matched to a known device. Within that message will be the DeviceID for that instance of the application enclosed in square brackets. e.g.[A123B654C987]. The ID is the part between (not including) the square brackets. Copy the ID from the HS log and enter it here.
Originally posted by rprade View PostThen you add that device ID to the PHL2 GF root device, just like PHL1.HS 4.2.8.0: 2134 Devices 1252 Events
Originally posted by rprade View PostDid you capture the Device ID and add it to the root?
I have to go and get some take-out this evening so will test the new app to ensure that we are working, will advise if I run into issues. Question what Polling Interval are you currently using as default (I know that they change based on events)?Computer: CUK Intel NUC7i7BNH
Op System: Windows10 Pro - Work Station
HS Version: HS4 Pro Edition 4.2.6.0
Plug-Ins: BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLRoombaWifi 2.0.37.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.1,EasyTrigger 3.0.0.74,Harmony Hub 4.0.13.0,HSBuddy 3.25.614.1,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 3P 0.0.0.52,Random 3.0.0.2,Restart 1.0.0.7,rnbWeather 4.2.0.0,SDJ-Health 3.1.0.3,Sonos 3.1.0.59,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.14.0,Z-Wave 3.0.7.0,Z-Wave UI 1.0.0.0, and Jon00 scripts.
Randy, I'm using the same port as my HS3 which I is different than my PHL1 Server port, my HS3 port was changed from the default 80 (minor security change) to something different. I'm obviously using my PHL1 experiences and am trying to update my PHL2 experience, what I was able to do is add nine new Geofency devices within HS3 whilst doing GeoFency Entry/Exit test so it appears that the App is communicating with HS3.
We are heading out for dinner as well. I will be back in an hour or two.
Paul,
PHL2 is mostly configured and I have to say, bravo!
Paul or Randy,
Which API from Bing & Mapquest should we use? They both offer a number of different ones. I’m assuming (not usually a good idea) to choose reverse geocoding but wanted to check.
I copied the iBeacon info from one to another. The original will on Geofency go near/not near but the “copy” with a different name will not. Any ideas?
Michael
Paul or Randy,
WRT API codes, it is late. I will try to post tomorrow.
I've uploaded version 3.0.0.38
The link is in post #1
This version fixes FollowMee which wasn't working in the last version along with some other small bugs.
From the support requests I have already handled there are a couple of things I think are worth pointing out.
1. When adding new or changing existing Service Accounts and / or User Devices within the plug-in it is imperative that you go to the PHLocation2 tab within the device config page and hit the Save Changes button. Failure to do this will result in the device configuration options not being saved.
2. There appears to be some confusion over how polled service accounts work so I will attempt to explain.
With a polled service account (iCloud, Life360, FollowMee). The plug-in polls the account at a user specified interval and obtains information for all devices linked to that account. There could be any number of devices linked to an account.
Adding these type of accounts to the plug-in is a 2-stage process.
Stage - 1
A Service Account is added where you provide the user credentials to access the service.
This will create a group of 3 devices. Root, Account Status and Polling Interval.
The Root device holds the account configuration.
The Account status device does just that (shows the account status) and has a button to force a manual poll. Between polls the status will show as "Waiting".
The Polling interval device is as its name suggests used to control the polling interval.
When a Service Account has been added and saved, go to it's Account Status device in the main HS3 device management page and hit the Poll button.
Assuming the credentials are OK, it will then poll the account and obtain a list of devices linked to the account.
Stage - 2
The plug-in does not automatically add all devices from an account to HS3. This is so the user can choose which devices to add.
An example may be an iCloud account that has 2 iPhones, 3 iPads and and some MacBooks. The user may not want to be tracking the location of some of those devices so it is pointless adding them to the plug-in.
In the case of iCloud, more devices being tracked slows things down.
Once an initial successful poll has taken place the plug-in will have an internal list of "Heard Devices" for an account.
From the Users/Devices page you can choose which of these devices you want included in the plug-in.
NOTE:
A device type will only show in the list if there are "Heard" devices for that service account type so a poll must be done first.
Paul..
