Reconnected about 3 hours ago and all seems OK. Went for a walk and data shows up on my map. Not getting any notices from Apple that someone is trying to login. Will keep my fingers crossed.
PHLocation V2 Discussion
This is a sticky topic.
I can verify that I too was able to get my 2FA for iCloud Service to provide a working code which I did Saturday evening and it seems to be work still (waiting for shoe to drop!)
Paul, has something changed or was this an anomaly? MikeComputer: CUK Intel NUC7i7BNH
Op System: Windows10 Pro - Work Station
HS Version: HS4 Pro Edition 4.2.6.0
Plug-Ins: BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLRoombaWifi 2.0.37.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.1,EasyTrigger 3.0.0.74,Harmony Hub 4.0.13.0,HSBuddy 3.25.614.1,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 3P 0.0.0.52,Random 3.0.0.2,Restart 1.0.0.7,rnbWeather 4.2.0.0,SDJ-Health 3.1.0.3,Sonos 3.1.0.59,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.14.0,Z-Wave 3.0.7.0,Z-Wave UI 1.0.0.0, and Jon00 scripts.
Well the proverbial "Shoe has dropped" once again I'm unable to request a 2FA key and am now getting the following error message..
Apr-16 3:21:25 PM PHLocation2 Error (PollAccount) Auth failed for AppleId: XXXXX@XXX.com Check Apple credentials. Apr-16 3:21:25 PM PHLocation2 (PollAccount) Internet OK. Checking for iCloud service availability. Apr-16 3:21:24 PM PHLocation2 Warning (PollAccount) idmsaAuth failed for iCloud account:XXXXX@XXX.com Checking for internet availability. Randy you made mention the Paul was looking to release a new version do we per chance have a status? MikeApr-16 3:21:24 PM PHLocation2 Error (idmsaAuthenticate) Missing result data for Ref:70 Computer: CUK Intel NUC7i7BNH
Is there any status on the 2FA for iCloud solution? I noticed that the thread seemed to be quite for the past week or so. MikeComputer: CUK Intel NUC7i7BNH
Guest
We based on others indicating that the 2FA is working (limited to a month) I tried to re enable my icloud service and requested a new 2FA code but received the following error and idea what's happening and what to do? Mike
Apr-25 7:41:31 PM PHLocation2 Error (idmsaAuthenticate) Missing result data for Ref:70 Computer: CUK Intel NUC7i7BNH
Think I got this setup correctly with Egizone⦠it even saw my first zone (home).
but no devices are showing up in device manager. this is what the log looks like:
Apr-26 8:15:05 AM PHLocation2 (BuildDeviceLists) Device list rebuild complete. Apr-26 8:15:05 AM PHLocation2 (BuildDeviceLists) No external devices to monitor, disabling monitoring. Apr-26 8:15:05 AM PHLocation2 (BuildDeviceLists) Found a total of 2 root and 1 child devices. Apr-26 8:15:05 AM PHLocation2 (BuildDeviceLists) Added Egi Fence root device 1324 : EgiGeoZone Fence to known F list. Apr-26 8:15:05 AM PHLocation2 Error (BuildDeviceLists) Error: DeviceID EDO is nothing for EgiFence Ref:1323 Apr-26 8:15:05 AM PHLocation2 (BuildDeviceLists) Rebuilding device lists following a config change. Apr-26 8:15:05 AM PHLocation2 (AddRebuildChildDevices) Created 1 child devices for EgiGeoZone FenceRef:1324
Some questions regarding PHLocation. First some background - I'm a longtime user and fan of PHLocation V1. I use it with Geofency to trigger events when an iPhone goes in and out of specified fence areas. I also have iBeacons in my home and cars so Geofency can tell if we're at home or in the car. So far, I've only used Geofency with PHLocation. I haven't had a need (yet) for HomeSeer to know our actual locations. When I need to know someone's location, I can use the iPhone's "Find Friends" app. But, I haven't had a use-case for sending location-specific (e.g. latitude/longitude) information to HomeSeer. Having said that, some questions:
1. Other than "keeping up to date" for future fixes/enhancements, if Geofency is all I need for now, any benefits to upgrade from PHLocation V1 to V2?
2. Is the interface between PHLocation V2 and Apple location information based on official Apple APIs?
3. If I don't need location-specific information (latitude/longitude), is Geofency still the best way for Geofence use, or can built-in Apple functionality provide Geofence info to PHLocation so as not to need Geofency?
Regards.
sooty
I'm seeing an issue when leaving my home area. I've noticed that after just one or two location updates (I have Backitude sending updates every 30 seconds with a minimum distance to move set to .08 miles), my Home Direction will change from Stopped to Approaching. My path leaving home winds back around through the neighborhood so I'm sure that between the first and second location update that my distance may get closer to Home. The issue is that I thought there is supposed to be at least 3 location updates before the direction is updated from Stopped to either approaching or leaving. It's almost like the plugin is remembering the last updates from the previous day and sn't being reset to 0 when the direction changes to stopped after I've been home for some time.
Here are my config file values:
HomeLocDirTimeOut=5
HomeLocDirCount=3
HomeLocDirBuff=128
