Originally posted by racerfern
View Post
PHLocation V2 Discussion
This is a sticky topic.
Originally posted by sooty View Post
Static maps are not currently part of V2 although I've added it to the todo list.
Paul..Computer: CUK Intel NUC7i7BNH
Op System: Windows10 Pro - Work Station
HS Version: HS4 Pro Edition 4.2.17.2
Plug-Ins: AK Weather 4.0.5.25,APCUPSD 3.3.2.3,BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.2,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,iRobot 5.22.41.1,JowiHue 4.0.8.7,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 4.0.10.0,Random 3.0.0.2,Restart 1.0.0.7,Ring 1.0.0.9,SDJ-Health 3.1.1.3,Sonos 3.1.0.59,Sonos4 4.0.1.12,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.32.0,Zigbee 4.0.11.0,Z-Wave 4.0.3.0, and Jon00 scripts.
Originally posted by rprade View PostWelcome to my world. My 65th birthday was a week ago Friday. It is fun to get to the point where you can hide your own Easter eggs(by only two years), Mike
Paul, looking in my HS3 log I noticed the following PHL2 error messages after an event (each one occurred separately);
Jan-13 3:24:33 PM PHLocation2 Error (UpdateFenceDevices) Error writing fence change to DB! Jan-13 3:24:33 PM PHLocation2 Error (InsertFenceData) Exception: SQL logic error or missing database near "0": syntax error Jan-13 3:29:28 PM PHLocation2 Error (UpdateFenceDevices) Error writing fence change to DB! --------------------------------------------------------------------------------------------------------Jan-13 3:29:28 PM PHLocation2 Error (InsertFenceData) Exception: SQL logic error or missing database near "1": syntax error Jan-13 3:33:26 PM Event Event Trigger "Location PHL2 mapping - Mike" Jan-13 3:33:25 PM PHLocation2 Warning (UpdateUserDevice) Primary elevation lookup failed, trying alternative provider. Jan-13 3:33:25 PM PHLocation2 Error (GetElevationA) Error: Error. Empty response. Jan-13 3:33:18 PM PHLocation2 Warning (UpdateUserDevice) Primary reverse geocode lookup failed, trying alternative provider! Jan-13 3:33:18 PM PHLocation2 Error (GetReverseGeoQ) Error: Empty Response. Computer: CUK Intel NUC7i7BNH
Paul or Randy,
When I first installed PHL2 I created one of my Geofency devices and now I have finished creating the rest of them after I updated to .41. I noticed that the new devices show "Inside" and "Outside" instead of "Near" & "Not Near", am I able to change them to "Near" & "Not Near" or will that screw up the plugin?HS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
HS4 Pro, 4.2.18.9 Windows 10 pro, Supermicro LP Xeon
When I first installed PHL2 I created one of my Geofency devices and now I have finished creating the rest of them after I updated to .41. I noticed that the new devices show "Inside" and "Outside" instead of "Near" & "Not Near", am I able to change them to "Near" & "Not Near" or will that screw up the plugin?HS 4.2.8.0: 2134 Devices 1252 Events
Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
Thanks Randy. Something else, I've entered more known locations and put a check mark in the box to enable, the plugin used to show time and distance for each of those locations, was that changed in this version? I don't see any of the locations show up as devices so I assume it now just shows if you are at or close to those known locations?HS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
Originally posted by sparkman View Post
Odd, all my Geofency devices created by PHL2 show as "Near" and "Not Near".HS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
