PHLocation ideas
    #31
    Randy, I'm not sure what I'm doing wrong I thought I was setting up a simple trigger that if I enter any known location and its not Home then say what known location I'm at and write the same within the HS3 Log but that's not happening, what am I missing?
    Computer: CUK Intel NUC7i7BNH
    Op System: Windows10 Pro - Work Station
    HS Version: HS4 Pro Edition 4.2.6.0
    Plug-Ins: BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLRoombaWifi 2.0.37.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.1,EasyTrigger 3.0.0.74,Harmony Hub 4.0.13.0,HSBuddy 3.25.614.1,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 3P 0.0.0.52,Random 3.0.0.2,Restart 1.0.0.7,rnbWeather 4.2.0.0,SDJ-Health 3.1.0.3,Sonos 3.1.0.59,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.14.0,Z-Wave 3.0.7.0,Z-Wave UI 1.0.0.0, and Jon00 scripts.
      #32
      I don't know what the problem is by your description. If you are saying the Event never runs, you need to break it down and see if the Trigger or the Condition is the problem. First remove the Condition and see if it speaks and logs the entry into known locations other than "Home". If that works, you would add your condition and see if it then stops. If that is the case, there is either a problem with the overall logic, or PHL is not seeing you enter a known location that is not home.
        #33
        Thanxs Randy, based on my conditions; if I enter any known locations which includes "None" and if doesn't include "Home" then execute speak and write within HS Log (which works when depressing "Run the Event" ">" button) but when I look at my timestamps it seems to not happen when I would have expected.
        Update: I think I know what has happen the "Any" known location includes "None" which stays on for a considerable time like when I leave home until a known location has been reached, so I've added another AND IF condition that the Current location has a value not equal to "None" should then trigger only on the known locations. I told you before I'm a little slow but can learn over time.. Mike
          #34
          Michael, I've had a chance to start looking at other solutions and I was interested in your Blue Iris routine can you share a snapshot of what your "Cameras - BI - Work and Home" event entails to turn BI camera's On/Off? thanxs Mike
          We currently Disable/Enable cameras. The Blue Iris PI author has written that he will implement Hide/Unhide which will allow for recording but they won’t display.
          Michael
            #35
            Michael, thanxs for the comeback. I'm assuming that your BI event is a manual Event using the "Blue-Iris: Camera Actions" trigger that either "Enable" or "Pause" a selected camera? Mike
              #36
              I was tired last night and my event picture didn’t post for some reason. Here it is:
              Michael
                #37
                Thanxs Michael, thanxs for sharing a picture is worth a thousand words.... I have 9 camera's and like the approach of disabling/enabling them depending on home state. Mike
