Trial Mode: (RequestRegKey) WE:The operation has timed out
    I thought I would upgrade to V2 today. After install I noticed "Trial Mode" and attempted to register. It didn't appear to work so I checked the log and noticed the following:
    Is something wrong on my end or where the plugin is trying to connect?
    Thanks!
    HS4, Insteon, Z-wave, USB-UIRT, Google Hub/Chromecasts/Speakers, Foscam & Amcrest cameras, RCA HSDB2a doorbell
    Plugins: BLLAN, BLOccupied, BLUSBUIRT, Chromecast, Harmony Hub, Insteon, Jon00 Homeseer/Echo Skill Helper, Jon00 DB Charting, MediaController, NetCAM, PHLocation2, Pushover 3P, weatherXML, Z-wave
    I get the same error...
      When I try to register, I get the message asking to wait for the registration to complete. After that dialog box goes away, nothing has changed. I still appear to be in trial mode. I get the same error message in my log as the OP
        The timeout issue when registering is fixed. Sorry for the inconvenience.
        Paul..
          I decided to post to this thread even though it has been months since anyone posted in it.
          I seem to be having the same problem as described in the above posts.
          When registering the plugin i'm getting a timeout issue in the HSlog.
          Anything i can do on my end?
            I've posted on same issue at start of Oct and have just had the plug in time out on me. Would suggest you don't waste your time any longer. I'm going to try and get PHLocation plug in running again and leave this alone until (or if) it moves forward from abandonware. Not sure why it is listed as available as Homeseer plugin to be frank.
            Good luck.
              Thank you for your reply. I will try to contact scooty and hopefully he will respond
                Paul will be uploading a version that does not require registration in the next few days. See the sticky at the top of the forum
                  From Paul;
                  Originally posted by sooty
                  I have now uploaded new versions of plugins that don’t need registration.
                  If users have already installed and run out of trial period then they will need to delete the plugin’s ini file and then run the new version.
                  The new version is 3.0.0.64. You can see the post with version information here, or download the new version here.
