Remove PHLocation 1
    Remove PHLocation 1
    I have PHLocation2 running and everything switched over so I am trying to remove the original PHLocation. I have clicked on the "Uninstall this Plugin" button on the Manage page of the plugins, but it isn't removing it. Is there another procedure I should be following?
    Thank you
    Bump.....
      just do it manual, select it and press delete, restart homeseer.
      Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
      HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
        Are you referring to the .exe file itself? I'm in the same boat as the OP.
        Also, can we then simply delete the old PHL1 devices? Anything special to take into consideration?
        Thanks!
        HomeSeer 3, Insteon, Z-wave, USB-UIRT, Google Hub/Chromecasts/Smart Speakers, Foscam cameras, Amcrest camera, RCA HSDB2a doorbell
          Thanks!
          Just disable the plug-in, delete the .exe and delete the HS devices associated with the original PHL. You can also remove the config files. There is no problem deleting the devices, but make sure by filtering Events that none of them are still used in Events
          Randy Prade
          Aurora, CO
          Prades.net
            Thanks! Good tip on the Event filtering. Of course I'll need to do a text search on my scripts directory as well. I think I got everything already but filtering/searching is an easy way to be certain.
