I updated my Geofency the other day to 6.1.5 and now it seems the webhooks aren't working. I have been using https:/connected2.homeseer.com/phl2api?dtype=GF as URL Http method POST and credentials have not changed for months without error. Plugin is no longer responding. When I test the webhook manually I get the following: Has anyone else noticed this?
Plugin not working on lastest version of Geofency
I'm experiencing the same issue as of yesterday afternoon.HS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
I am running 6.1.5 as is Michelle. Both of ours are posting just fine. I don't see an image of the error in the first post. I use the same URL for posting. Can you get log into MyHS using the same credentials? Have you tried reentering your MyHS credentials into GeoFency on one of your fences?
Originally posted by rprade View PostI am running 6.1.5 as is Michelle. Both of ours are posting just fine. I don't see an image of the error in the first post. I use the same URL for posting. Can you get log into MyHS using the same credentials? Have you tried reentering your MyHS credentials into GeoFency on one of your fences?
It may be something temporary or local. Here https://connected2.homeseer.com resolves just fine, asks for and accepts my credentials.
Originally posted by rprade View PostIt may be something temporary or local. Here https://connected2.homeseer.com resolves just fine, asks for and accepts my credentials.
The original URL still is not working. It gets me to the logon page but throws the exception when I log in and gives me this page:
Is this an issue with Homeseer rather than the plugin? Confused as to why it is only affecting some plugin users. Also strange that this seemed to happen after Geofency update. Wish Paul was around to troubleshoot. I guess in the mean time I'll change all my location URLs. It's just adding one "2" so it's fairly painless
I can confirm that changing my URL to use connected22 without updating my credentials has corrected the issue.
Sent from my iPad using TapatalkHS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
Originally posted by The Profit View PostI can confirm that changing my URL to use connected22 without updating my credentials has corrected the issue.
Originally posted by rprade View PostAnd mine is still working fine today with https://connected2.homeseer.com/ and has not failed in months. I'm at a loss as to why it resolves here, but not for others. I think that connected2.homeseer.com is the load balancing server where connected22.homeseer.com is an individual server.
Plugin's:
After 5:30pm tonight GF stopped working for us again using connected22. I changed it back to connected2 and it works. I’m wondering if connected2 is the load balancing server or not? Has anyone checked with support to see if we are using the correct link?
Originally posted by rprade View PostWhen Paul first suggested using MyHS for posting, Rich verified that connected2 was the correct URL to use. I think it was an email we exchanged, but I cannot find it now.
Plugin's:
- 1 like
