How do I get PHLocation plugin downloaded to HS4
PHLocation2 in HS4
Originally posted by dparks View PostHow do I get PHLocation plugin downloaded to HS4
It does work in HS4 as a legacy plug-in. I will see about creating an updater_override.json file or an alternate method of installation.
HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Randy you can also install Jon00 links which allow you to run the Legacy HS3 Plugin Management and you could use the HS3 updater from there I believe. I installed another HS3 plugin (can't remember which one) from there and it worked just fine. You can also see your HS4 plugins there, start stop etc. Just a thought.
OK, here you go. This is not for the faint of heart but i did just test it. I have attached a zip file to this post. It contains all the files needed for PHL2 to run under HS3. Inside the zip is a folder HomeSeer HS4. Under that folder are two files and two directories. Copy all of that to your HomeSeer root.
You will need to manually start the HSPI_PHLocation2.exe file while HS4 is running. Then you should be able to enable the plug-in under the Plugins management
If you don't see it, restart HS4. Once enabled, you should be able to configure it normally as if under HS3. The help documentation for HS3 is in the link I posted above. The zip file I created is attached.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
- Likes 2
Originally posted by Bigstevep View PostRandy you can also install Jon00 links which allow you to run the Legacy HS3 Plugin Management and you could use the HS3 updater from there I believe. I installed another HS3 plugin (can't remember which one) from there and it worked just fine. You can also see your HS4 plugins there, start stop etc. Just a thought.
Originally posted by rprade View PostIt is still fully functional and the developer is working with me to see if we can find someone to take over the development.
Have you asked spud if he could make this an official homeseer supported plugin?
Lack of geofencing and location awareness is a major gap in homeseer compared to competitors. Spud taking this and making it a fully supported homeseer plugin would close that gap overnight. Plus I personally think Spud would be a great person to carry on what snevl started and Paul built on.
Just a thought.
Sent from my iPhone using Tapatalk Pro_______________________________________________
HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
- Likes 3
Originally posted by jlrichar View Post
Randy,
Just a thought.
- Likes 2
Originally posted by rotunnoe View PostI'm just curious if PHLocation2 does indeed fully work with HS4. Specifically with GeoFency. I know when i tried the HS4 beta a few months ago it wasn't working.HS4 Pro on Shuttle NC10U, Win10; Z-NET
Number of Devices: 1005
Number of Events: 293
Plug-Ins: BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, Marquis monoprice Amp, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, rnbWeather, Worx Landroid, Z-Wave
External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
Randy, slow question I take it that iCloud Services are not working, I noticed that when I do a 2FA Controls code, it submits the request to the iPhone as I get a code but within the PHLocation2 I get an error message first "Request Failed. Check Log for details." when I enter the proper code from iPhone I get "Click Request Code first!" even though PHLocation2 made the proper request is there a work around? Mike
Side Note: Have you made the total transition to HS4 and if so what HS3 capabilities did you lose if any?
UPDATE:
Well after scanning through the many PHLocation2 threads within this plugin topic I believe the short answer is... For iPhone users you must delete both iCloud Services and Devices since PHLocation2 in its current state can no longer supported it.
From the many responses, I believe that the corresponding PHLocation2 S/W code is still MIA and there is no software Developer in the wings to pick it, Randy can you confirm this?
I did see that for iPhone users the only replacement for the now defunked PHLOCATION2 - iCloud Services is the Followmee App, the down side is that it now costs with yearly fees for both the basic and API services. Which potentially means that we will have two apps running on the iPhone; Followmee as the iCloud replacement and GeoFency, must be the price of technology I guess!Computer: CUK Intel NUC7i7BNH
Op System: Windows10 Pro - Work Station
HS Version: HS4 Pro Edition 4.2.19.0
Plug-Ins: AK Weather 4.0.5.25,APCUPSD 3.3.2.3,BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.2,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,iRobot 5.22.41.1,JowiHue 4.0.8.7,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 4.0.10.0,Random 3.0.0.2,Restart 1.0.0.7,Ring 1.0.0.9,SDJ-Health 3.1.1.3,Sonos 3.1.0.59,Sonos4 4.0.1.12,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.32.0,Zigbee 4.0.11.0,Z-Wave 4.0.3.0, and Jon00 scripts.
Originally posted by I did see that for iPhone users the only replacement for the now defunked PHLOCATION2 - iCloud Services is the [BFollowmee[/B] App, the down side is that it now costs with yearly fees for both the basic and API services. Which potentially means that we will have two apps running on the iPhone; Followmee as the iCloud replacement and GeoFency, must be the price of technology I guess!
