PHLocation2 in HS4
    #46
    Originally posted by Wade View Post
    I've been getting this continuously in the log for the past 4 hours or so. Anyone else having issues? I use PHLocation2 with Life360 on Android phones. Not sure whether it might be a L360 server issue or something on my side. I've restarted to plugin to no avail.
    Click image for larger version Name:	Capture.jpg Views:	0 Size:	202.4 KB ID:	1560202
    edit: Or I suppose L360 could've changed their data format, in which case I'm dead in the water with PHLocation2...
    I wanted to follow up this post in case anyone comes along later with a similar issue. It seems these errors are related to an inactive Life360 user. It's only anecdotal, but here's what I observed:
    At some point months ago, I started getting these errors on every poll of the Life360 servers. It went on for some time--I ignored it due to lack of time to implement another solution and the fact that everything else seemed to be working properly. Then at some point the errors stopped for a few weeks and then began again (about a month ago). In hindsight I've realized the initial start of the errors roughly corresponded to one of our Life360 Circle users getting a new phone. The errors stopped around the time when L360 was finally installed and activated on the new phone. Then the user stopped using Life360 again around the time the errors restarted. This is when I noticed the correlation. I tried disabling the user in the L360 plugin, but it had no effect. I then deleted the user from our Life360 "Circle" and from the L360 plugin config, and the errors disappeared. No idea why an inactive user causes the problem and it will never be fixed since the plugin is abandoned, but maybe this will help someone in the future.
    -Wade
      #47
      Wade it helps a lot, thanks. I posted about the same error months and months ago without resolution. For now I'm using HSBuddy for some simple geolocation but might give PHLocation2 a go once again even though it's abandonware.
        #48
        Following Wade post, I tried again. PHL2 appears to be working but I cannot add a Life360 user. I realize there is a limitation of two, but where it this info stored? I'm willing to remove all files and start from scratch, but I thought I had done that previously. Still the same problem, cannot add a Life360 user as two of them are stored in some file.
        Anybody?
          #49
          Originally posted by randy View Post
          OK, here you go. This is not for the faint of heart but i did just test it. I have attached a zip file to this post. ...
          If you don't see it, restart HS4. Once enabled, you should be able to configure it normally as if under HS3. The help documentation for HS3 is in the link I posted above. The zip file I created is attached.
          I would like to install PHLocation by this method. However, there is no file attached to this post. I know it has been a few years, but could you please post the file? Thanks.
          "Living with technology means living in a [constant] state of flux."
          S. Higgenbotham, August 2023
            #50
            Not sure why you’re not seeing it. The file is still attached to the post.
            HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
              #51
              I see it now.
                #52
                Click image for larger version  Name:	image.png Views:	38 Size:	69.6 KB ID:	1611158
                I guess I'm blind, too because I don't see the attachment.
                I would like to install as we are in a new home and embarking on HS4.
                I have PHLocation2_3_0_0_64.zip and updater_override.txt. However, when I open the zip file I do not have the same folders as you described.
                Michael
                  #53
                  When I get back to my desk I’ll post a link. A couple of hours.
                    #54
                    Well, the link is there - thanks.
                    Michael
                      #55
                      Well that's interesting. On July 29th PHLocation2 threw an error that continues today. I can't get location info, maps or anything else. It was working perfectly prior to this point in time.
                      I didn't restart anything or update anything. It's out of the clear blue.Anyone else?
                      I remember this error popping up previously, but I don't remember what made it go away.
                      7/29/2023 17:42:26 Legacy-Plugin/Script PHLocation2 Error (PollAccount) LF Error in GetCircles.
                        #56
                        Life360 changed their API on 7/29/23. Shill is dealing with it with his Life360 plugin which I'm now using. Unfortunately may be the death knell for PHLocation2 & L360.
                        -Wade
