Are you selecting the com port that the modem is connected to?
Can you post some log entries that shows what errors are being generated please?
2016-03-01 22:16:52 Plug-In Finished initializing plug-in SMS-Gateway
2016-03-01 22:16:52 SMS-Gateway Debug Connectecting on COM2 with Baud 9600 | DataBits Eight | Parity None | StopBits One
2016-03-01 22:16:52 SMS-Gateway Debug InitSMS() called
2016-03-01 22:16:52 SMS-Gateway Debug Found existng Signal device with address: SMS-Signal
2016-03-01 22:16:51 SMS-Gateway Debug Found existng Sender device with address: SMS-Sender
2016-03-01 22:16:51 SMS-Gateway Debug Found existng Message device with address: SMS-Message
2016-03-01 22:16:51 SMS-Gateway Debug Found existng Date device with address: SMS-Date
2016-03-01 22:16:51 SMS-Gateway Debug NLog v4.0.0.0
2016-03-01 22:16:51 SMS-Gateway Debug Toolkit.Core v1.8.1.0
2016-03-01 22:16:51 SMS-Gateway Initialising SMS-Gateway v3.3.3.32005 on COM2
2016-03-01 22:16:51 SMS-Gateway Debug OS is windows and port is COM2
2016-03-01 22:16:51 Info Plugin SMS-Gateway has connected. IP:127.0.0.1:50886
2016-03-01 22:16:50 Plug-In Interface SMS-Gateway is running as a trial, 30 days remaining.
2016-03-01 22:16:42 Info Plugin SMS-Gateway with instance: has disconnected
So the signal device is showing you have no signal? It's possible this modem does not support signal strength information.
Did you try to send/receive an SMS?
2016-03-01 23:33:46 SMS-Gateway Error Error sending SMS - not connected to modem/phone - restart Plugin or wait for reconnect attempt
2016-03-01 23:33:46 SMS-Gateway Debug Send an SMS to 14693693602 saying testI created a manual event
In the logs folder there should be a file called HSPI_SMSGW_Modem.log that shows the detail of the interaction with your modem. Can you mail that to me Gavin<at>highpeak.co.za
Also, can you confirm communication with the modem on COM2 via a terminal emulator such as putty? Shutdown the plugin, run putty, connect to COM2 at 9600 baud and enter 'AT<enter>' you should get an 'OK' response.
