Number Block Mask Issue
  • alphatech
    Thanks UltraJones, I wish I was a programmer so I didn't not need to bother you anymore. Thanks for everything.
    Sent from my SM-S906U using Tapatalk
  • Ultrajones
    No, I did not keep any older versions. However, I did release the source code! Feel free to review it/change it as you see fit.
  • alphatech
    UltraJones, do you have a early version that we can try?
  • will40
    I tried both regex examples above as well and no go either. I agree something in the recent PI version 3.0.6681.34300 perhaps isn't working right.
    Thank you guys for the help along the way. I am able to block the numbers individually but to block by the area code would be ideal.
  • alphatech
    I tried it without success, I think few of the modules or code are not working and maybe there were working before. Do you still have a previous plugin release that I can try?
  • Ultrajones
    Okay, one last suggestion, try this (this would allow a character before the area code)
    (8(00|88|77|77)|617)\d{7}
  • alphatech
    @ewkearns​ I tried it, same results but thanks for your suggestion.
  • alphatech
    I tried every combination but I will try this one to, will keep you posted. What is strange is that the Plugin works with some code but not for other, it will block the number if you tell him to block it in the number log but the drop event and the musk does not work. I was planning to write a code that Sue the event to drop but that function is not working either. I understand that ultra Jones is not supporting it anymore and is fair but I'm almost there, it is like going over "99 doors" but stuck on the last door and I ca not get out😁
    Happy holidays
  • ewkearns
    Regex will be a perpetual mystery to me, but I think this will work: ^8(00|88|77|66|)|^6(17)
  • alphatech
    UltraJones, I guess Santa is not bringing any gift this year. The only hope would be if UltraJones gives me one instead by helping fixing this problem :-)
    Happy holidays all.
  • alphatech
    As an FYI, also the Drop event is not working. I was trying to create a script that can call this event a drop the call based on the caller id, unfortunately the only option that I have is using the caller log and mark it as blocked and since telemarketer change numbers every time, this option is not a viable solution.
  • alphatech
    Will40 thanks for verify it. Indeed it blocks the number only if is in the caller log and is blocked.
  • will40
    guys I just tried it as well and it does not block incoming callers with the 617 area code. The modem drop caller command does work if I edit my callerid in the Caller Log and instruct it to block.
    From my earlier tests the Use Number Block Mask did not work for me no matter what regex I tried. Even my own alternate phone number.
  • alphatech
    UltraJones, thank you for trying. Unfortunately is not working and you already spent lot of time looking at this issue. I have attached the screens for reference.
  • alphatech
    Thank you ultra Jones, happy holidays. I will check it out today and post the results back. So many telemarketers nowadays 🤣
