I was just wondering if there was a way to speak the number when a callers name is not available, I tried the $nmbr string in the Announce Phrase with no luck.
Speaking number
mikeeTags: None
mikee
I guess this is actually more complicated that I originally thought, speaking the number speaks as a single number instead of separate digits e.g. one million five hundred thousand etc, wondering if there is an easy way around this, Also came across a minor bug in the caller log, when there is more than one page the "jump to page" box at the top works fine but the one at the bottom of the page always takes you to page 1
UJ-
What he needs is some code where it trims leading ones like for VOIP CID numbers and to add dashes to the number.
So CID Number 1-503-555-1212, 5035551212 or 15035551212 would present 503-555-1212 to your variable. I found various telco systems present the CID differently.
I had a script that I can't find that took all the dashes (if any) out, trimmed all but the last seven digits, then add the dashes back in.
Easy code for a VBGenius like yourself
~Bill
Sorry, I have not been able to reply. I understand what you need and will post update soon. I'll see if I can use the number format from the options web page so it speaks the caller number correctly.
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Originally posted by danielbo View PostWhere do I find information on ultra CID? I would like to see what features it has, always looking for new stuff for my HSP. I am using Blades and it is to tell you that you have a call waiting and it works only about 1/3 the time. I really like this feature when it works.
Danielbo
The helpfile is available here:
http://automatedhomeonline.com/HomeS...sers_Guide.pdf
mikee
