easy export?
    easy export?
    Any tips for an easy export of Caller ID log to CSV?
    Thanks!
    UltraCID HSPI currently does not have an export function. Are you looking to export all data in the caller log?
      Export
      Sorry for the slow response, somehow I didn't see your reply.
      I'd like to get a sortable / editable log of callers into excel for reporting purposes. The immediate need is for a list of calls (dates, times, received caller ID info) from a certain company that includes all originating numbers that they use to call me. I thought rather than ask you to build a reporting engine into the plugin, maybe a quick CSV export would get the data to a tool I can use to do the heavy lifting.
      Along these lines - I'd like to be able to preserve the original received caller ID name while also associating a "nickname" of sorts. Am I right in assuming that currently when I edit a caller name I lose the original caller name as received from the telco? Currently I modify the caller name field once I figure out who the caller actually is, but am I doing so at the expense of knowing what the original received caller name is in the future?
        Sorry, not sure if i answered you actual question. a complete export of the entire caller log would be fine. the ideal would be to add an export button next to the filter button on the caller log page, with the filter options set in the various drop-downs etc. applying to the export in the same way as the filter....hit filter to display on screen (as it does now), hit export to give same results in a CSV file.
        FYI - tiny bug on the caller log page - if the log displayed is more than one page (more than 25, 50, etc. records), only the page number drop down on the top of the page works to change to other pages. If you use the one at the bottum of the page, it shows page 1 regardless of the page number selected.
          I have also noticed the bug on the lower drop-down page selector. CSV export would be cool.
