Cant's get my U.S. Robotics PCI modem to work with UltraCID...
    I dont's know why, but I can't get my modem to work with UltraCID. My modem is an almost new U.S. Robotics 56K PCI modem that work very well with Girder's caller ID plugin and other caller ID software I've tried. I can connect le modem to the plugin, status is "OK" but I get always the same error in the log at startup: UltraCID Warning - No response/improper response from modem command 'AT+VCID=1'. Same error for all the init string set in the plugin. And then I get: Error - Initializing interface: UltraCID->Could not initialize modem caller ID!
    I've tried those init string in HyperTerminal and some work, some don't.
    ATQ0V1E0
    OK
    AT+GMM
    OK
    AT+VCID=1
    OK
    AT+FCLASS=8
    ERROR
    AT-STE=7
    ERROR
    Even id AT+VCID=1 work, I always get an error in the plugin: "UltraCID Warning - No response/improper response from modem command"...... but it work in Hyperterminal and all the other CID software!!
    I can see how many call was received, number of rings, but any info about the last aller remind UNKNOW and queries to the database report nothing...
    Please help!
    Hello. Please enable debug, then restart Homeseer, then send me the logs showing the initialization.
    Ultrajones
      13/12/2010 7:55:29 AM - Startup -
      13/12/2010 7:55:29 AM - Startup - ************************************************************ ********************
      13/12/2010 7:55:29 AM - Startup - HomeSeer version 2.3.0.19 Starting Now (PRO Build)
      13/12/2010 7:55:29 AM - Startup - Using system's regional settings
      13/12/2010 7:55:33 AM - Startup - Loading Settings
      13/12/2010 7:55:33 AM - Startup - Settings Loaded.
      13/12/2010 7:55:33 AM - Startup - Loading configuration file ...
      13/12/2010 7:55:34 AM - Info - Loading device types file...
      13/12/2010 7:55:34 AM - Database - Opening (Mode=Read) up HomeSeer database: D:\shares\Users\jfortin\Home Automation\HomeSeer.mdb
      13/12/2010 7:55:35 AM - Info - Loading Devices...
      13/12/2010 7:55:36 AM - Load Config - 26 total devices loaded.
      13/12/2010 7:55:36 AM - Load Config - Checking device type settings for all devices...
      13/12/2010 7:55:36 AM - Load Config - Finished checking device type settings.
      13/12/2010 7:55:36 AM - Load Config - Loading Events...
      13/12/2010 7:55:36 AM - Load Config - 23 total events loaded.
      13/12/2010 7:55:36 AM - Database - HomeSeer configuration database D:\shares\Users\jfortin\Home Automation\HomeSeer.mdb has been closed.
      13/12/2010 7:55:39 AM - Info - HomeSeer version is: 2.3.0.19
      13/12/2010 7:55:39 AM - Info - Initializing phone interface...
      13/12/2010 7:55:39 AM - HSPhone - HomeSeer Phone Web Interface initializing.
      13/12/2010 7:55:39 AM - Startup - Checking for available plug-ins
      13/12/2010 7:55:39 AM - Info - Found plug-in: X10 CM15AUSB, version: 1.0.0.6
      13/12/2010 7:55:39 AM - Info - Found plug-in: HSTouch Server, version: 1.0.0.33
      13/12/2010 7:55:39 AM - Info - Found plug-in: HSTouch Android, version: 1.0.0.0
      13/12/2010 7:55:39 AM - Info - Found plug-in: HSTouch iPhone, version: 1.0.0.0
      13/12/2010 7:55:39 AM - Info - Found plug-in: HSTouch Server Unlimited, version: 1.0.0.1
      13/12/2010 7:55:40 AM - Info - Found plug-in: iTunes, version: 2.4.0.20
      13/12/2010 7:55:40 AM - Info - Found plug-in: Media Player, version: 2.4.0.18
      13/12/2010 7:55:40 AM - Info - Found plug-in: Mixer, version: 1.0.0.114
      13/12/2010 7:55:40 AM - Info - Found plug-in: PowerLink, version: 2.0.1.0
      13/12/2010 7:55:40 AM - Info - Found plug-in: SeerAMP, version: 0.4.0.6
      13/12/2010 7:55:40 AM - Info - Found plug-in: Touchpad, version: 2.0.0.23
      13/12/2010 7:55:40 AM - Info - Found plug-in: UltraCID, version: 1.1.3809.11888
      13/12/2010 7:55:40 AM - Info - Found plug-in: Vista MCE, version: 1.0.0.4
      13/12/2010 7:55:40 AM - Startup - Restoring device status
      13/12/2010 7:55:40 AM - Startup - Initializing Plug-Ins
      13/12/2010 7:55:40 AM - Info - Initializing Plug-in: Media Player
      13/12/2010 7:55:41 AM - Media Player - MPAppThreadProc start
      13/12/2010 7:55:41 AM - Media Player - Loading library in the background, this could take a few minutes...
      13/12/2010 7:55:42 AM - Media Player - Found 9070 total tracks, loading library...
      13/12/2010 7:55:47 AM - Media Player - Warning, queued command did not complete due to timeout: set_repeat
      13/12/2010 7:55:48 AM - Info - Finished initializing plug-in Media Player
      13/12/2010 7:55:48 AM - HSTouch Server Unl - Register callback completed
      13/12/2010 7:55:48 AM - Info - Initializing Plug-in: HSTouch Server Unlimited
      13/12/2010 7:55:48 AM - HSTouch Server Unl - HSTouch Server Unlimited plugin initialized.
      13/12/2010 7:55:48 AM - Info - Finished initializing plug-in HSTouch Server Unlimited
      13/12/2010 7:55:48 AM - Info - Initializing Plug-in: Touchpad
      13/12/2010 7:55:48 AM - COM Plugin - Calling InitIO
      13/12/2010 7:55:48 AM - COM Plugin Info - Touchpad Initializing...
      13/12/2010 7:55:48 AM - Touchpad - Touchpad 2.0.23 starting.
      13/12/2010 7:55:48 AM - Startup - Touchpad is configured for HomeSeer 2.0
      13/12/2010 7:55:48 AM - Touchpad - Touchpad Configuration completed.
      13/12/2010 7:55:48 AM - Info - Finished initializing plug-in Touchpad
      13/12/2010 7:55:48 AM - Info - Initializing Plug-in: SeerAMP
      13/12/2010 7:55:48 AM - COM Plugin Info - Initializing SeerAMP...
      13/12/2010 7:55:48 AM - Database Item - Saving Device Media Player Volume
      13/12/2010 7:55:49 AM - Info - Finished initializing plug-in SeerAMP
      13/12/2010 7:55:49 AM - HSTouch Server - Register callback completed
      13/12/2010 7:55:49 AM - Info - Initializing Plug-in: HSTouch Server
      13/12/2010 7:55:49 AM - HSTouch Server - Registered for STATUS CHANGE callback.
      13/12/2010 7:55:49 AM - HSTouch Server - Registered for STRING CHANGE callback.
      13/12/2010 7:55:49 AM - HSTouch Server - Registered for CONFIG CHANGE callback.
      13/12/2010 7:55:49 AM - HSTouch Server - Registered for CALLER-ID callback.
      13/12/2010 7:55:49 AM - HSTouch Server - Registered for VALUE CHANGE callback.
      13/12/2010 7:55:49 AM - HSTouch Server - Registered for GENERIC EVENT callback.
      13/12/2010 7:55:49 AM - Info - Finished initializing plug-in HSTouch Server
      13/12/2010 7:55:49 AM - HSTouch iPhone - Register callback completed
      13/12/2010 7:55:49 AM - Info - Initializing Plug-in: HSTouch iPhone
      13/12/2010 7:55:49 AM - HSTouch iPhone - HSTouch iPhone plugin initialized.
      13/12/2010 7:55:49 AM - Info - Finished initializing plug-in HSTouch iPhone
      13/12/2010 7:55:49 AM - HSTouch Android - Register callback completed
      13/12/2010 7:55:49 AM - Info - Initializing Plug-in: HSTouch Android
      13/12/2010 7:55:49 AM - HSTouch Android - HSTouch Android plugin initialized.
      13/12/2010 7:55:49 AM - Info - Finished initializing plug-in HSTouch Android
      13/12/2010 7:55:50 AM - PowerLink - HSPI Hub loaded
      13/12/2010 7:55:50 AM - PowerLink - Register callback completed
      13/12/2010 7:55:50 AM - PowerLink - Connecting to PowerLink on 127.0.0.1
      13/12/2010 7:55:50 AM - PowerLink - Connected to PowerLink on 127.0.0.1
      13/12/2010 7:55:50 AM - Info - Initializing Plug-in: PowerLink
      13/12/2010 7:55:50 AM - PowerLink - Init Powerlink plugin
      13/12/2010 7:55:50 AM - PowerLink - Version 2.0.1.0
      13/12/2010 7:55:50 AM - Info - Finished initializing plug-in PowerLink
      13/12/2010 7:55:50 AM - Vista MCE - Register callback completed
      13/12/2010 7:55:50 AM - Info - Initializing Plug-in: Vista MCE
      13/12/2010 7:55:50 AM - Vista MCE - Server started on port 10300
      13/12/2010 7:55:50 AM - Vista MCE - Registered for STATUS CHANGE callback.
      13/12/2010 7:55:50 AM - Vista MCE - Registered for STRING CHANGE callback.
      13/12/2010 7:55:50 AM - Vista MCE - Registered for CONFIG CHANGE callback.
      13/12/2010 7:55:50 AM - Vista MCE - Registered for CALLER-ID callback.
      13/12/2010 7:55:50 AM - Vista MCE - Registered for VALUE CHANGE callback.
      13/12/2010 7:55:50 AM - Vista MCE - Registered for GENERIC EVENT callback.
      13/12/2010 7:55:50 AM - Info - Finished initializing plug-in Vista MCE
      13/12/2010 7:55:51 AM - UltraCID Debug - Entered Version() function.
      13/12/2010 7:55:51 AM - UltraCID Info - UltraCID version 1.1.3809.11888 starting ...
      13/12/2010 7:55:51 AM - UltraCID Debug - RegisterMenu callback executing...
      13/12/2010 7:55:51 AM - Info - Initializing Plug-in: UltraCID
      13/12/2010 7:55:51 AM - UltraCID Debug - Entered InitIO() function.
      13/12/2010 7:55:51 AM - UltraCID Info - UltraCID - initializing I/O ...
      13/12/2010 7:55:51 AM - UltraCID Debug - Entered InitHW() function.
      13/12/2010 7:55:51 AM - UltraCID Debug - Initiating connection to COM3...
      13/12/2010 7:55:51 AM - UltraCID Debug - Entered InitPluginDevices() function.
      13/12/2010 7:55:51 AM - UltraCID Debug - Verification of base IO code '\' for device class 'BaseClass' complete. Code currently in use.
      13/12/2010 7:55:51 AM - UltraCID Debug - Entered CreatePluginDevices() function.
      13/12/2010 7:55:51 AM - UltraCID Debug - Updating existing CID Monitoring State Device
      13/12/2010 7:55:51 AM - UltraCID Debug - Updating existing CID Database Device
      13/12/2010 7:55:52 AM - UltraCID Debug - Updating existing Phone Extension Device
      13/12/2010 7:55:52 AM - UltraCID Debug - Updating existing Last Caller Name Device
      13/12/2010 7:55:52 AM - UltraCID Debug - Updating existing Last Caller Number Device
      13/12/2010 7:55:52 AM - UltraCID Debug - ProcessCommandQueue Thread Started
      13/12/2010 7:55:52 AM - UltraCID Debug - Attemping to enable modem caller ID ...
      13/12/2010 7:55:52 AM - UltraCID Debug - Sending command: 'ATQ0V1E0' to modem, attempt # 1
      13/12/2010 7:55:52 AM - UltraCID Debug - Entered SendToModem() function.
      13/12/2010 7:55:52 AM - UltraCID Debug - Sending ATQ0V1E0 to modem serial port ...
      13/12/2010 7:55:52 AM - UltraCID Debug - Entered Serial DataReceived() function.
      13/12/2010 7:55:52 AM - UltraCID Debug - Waiting for the modem to respond with 'OK' for up to 2 seconds...
      13/12/2010 7:55:52 AM - UltraCID Debug - Entered ProcessReceived() function with a string [ATQ0V1E0]
      13/12/2010 7:55:52 AM - UltraCID Debug - Exited Serial DataReceived() function.
      13/12/2010 7:55:53 AM - Media Player - Loaded 500 tracks...
      13/12/2010 7:55:54 AM - UltraCID Debug - Waited 2031 milliseconds for the command response.
      13/12/2010 7:55:54 AM - UltraCID Warning - No response/improper response from modem command 'ATQ0V1E0'
      13/12/2010 7:55:54 AM - UltraCID Debug - Sending command: 'ATQ0V1E0' to modem, attempt # 2
      13/12/2010 7:55:54 AM - UltraCID Debug - Entered SendToModem() function.
      13/12/2010 7:55:54 AM - UltraCID Debug - Sending ATQ0V1E0 to modem serial port ...
      13/12/2010 7:55:54 AM - UltraCID Debug - Waiting for the modem to respond with 'OK' for up to 2 seconds...
      13/12/2010 7:55:54 AM - UltraCID Debug - Entered Serial DataReceived() function.
      13/12/2010 7:55:54 AM - UltraCID Debug - Entered ProcessReceived() function with a string [ATQ0V1E0]
      13/12/2010 7:55:54 AM - UltraCID Debug - Exited Serial DataReceived() function.
      13/12/2010 7:55:56 AM - UltraCID Debug - Waited 2046 milliseconds for the command response.
      13/12/2010 7:55:56 AM - UltraCID Warning - No response/improper response from modem command 'ATQ0V1E0'
      13/12/2010 7:55:56 AM - UltraCID Debug - Sending command: 'ATQ0V1E0' to modem, attempt # 3
      13/12/2010 7:55:56 AM - UltraCID Debug - Entered SendToModem() function.
      13/12/2010 7:55:56 AM - UltraCID Debug - Sending ATQ0V1E0 to modem serial port ...
      13/12/2010 7:55:56 AM - UltraCID Debug - Waiting for the modem to respond with 'OK' for up to 2 seconds...
      13/12/2010 7:55:56 AM - UltraCID Debug - Entered Serial DataReceived() function.
      13/12/2010 7:55:56 AM - UltraCID Debug - Entered ProcessReceived() function with a string [ATQ0V1E0]
      13/12/2010 7:55:56 AM - UltraCID Debug - Exited Serial DataReceived() function.
      13/12/2010 7:55:58 AM - UltraCID Debug - Waited 2046 milliseconds for the command response.
      13/12/2010 7:55:58 AM - UltraCID Warning - No response/improper response from modem command 'ATQ0V1E0'
      13/12/2010 7:55:58 AM - UltraCID Debug - Sending command: 'AT+GMM' to modem, attempt # 1
      13/12/2010 7:55:58 AM - UltraCID Debug - Entered SendToModem() function.
      13/12/2010 7:55:58 AM - UltraCID Debug - Sending AT+GMM to modem serial port ...
      13/12/2010 7:55:58 AM - UltraCID Debug - Waiting for the modem to respond with 'OK' for up to 2 seconds...
      13/12/2010 7:55:58 AM - UltraCID Debug - Entered Serial DataReceived() function.
      13/12/2010 7:55:58 AM - UltraCID Debug - Entered ProcessReceived() function with a string [AT+GMM]
      13/12/2010 7:55:58 AM - UltraCID Debug - Exited Serial DataReceived() function.
      13/12/2010 7:56:00 AM - Media Player - Loaded 1000 tracks...
      13/12/2010 7:56:00 AM - UltraCID Debug - Waited 2031 milliseconds for the command response.
      13/12/2010 7:56:01 AM - UltraCID Warning - No response/improper response from modem command 'AT+GMM'
      13/12/2010 7:56:01 AM - UltraCID Debug - Sending command: 'AT+GMM' to modem, attempt # 2
      13/12/2010 7:56:01 AM - UltraCID Debug - Entered SendToModem() function.
      13/12/2010 7:56:01 AM - UltraCID Debug - Sending AT+GMM to modem serial port ...
      13/12/2010 7:56:01 AM - UltraCID Debug - Waiting for the modem to respond with 'OK' for up to 2 seconds...
      13/12/2010 7:56:01 AM - UltraCID Debug - Entered Serial DataReceived() function.
      13/12/2010 7:56:01 AM - UltraCID Debug - Entered ProcessReceived() function with a string [AT+GMM]
      13/12/2010 7:56:01 AM - UltraCID Debug - Exited Serial DataReceived() function.
      13/12/2010 7:56:02 AM - UltraCID Error - Failed to initialize caller ID. The command at+vcid=1 failed.
      13/12/2010 7:56:02 AM - UltraCID Debug - Entered InitializeDatabase() function.
      13/12/2010 7:56:02 AM - UltraCID Debug - Entered OpenDBConn() function.
      13/12/2010 7:56:03 AM - UltraCID Debug - Waited 2046 milliseconds for the command response.
      13/12/2010 7:56:03 AM - UltraCID Warning - No response/improper response from modem command 'AT+GMM'
      13/12/2010 7:56:03 AM - UltraCID Debug - Sending command: 'AT+GMM' to modem, attempt # 3
      13/12/2010 7:56:03 AM - UltraCID Debug - Entered SendToModem() function.
      13/12/2010 7:56:03 AM - UltraCID Debug - Sending AT+GMM to modem serial port ...
      13/12/2010 7:56:03 AM - UltraCID Debug - Entered Serial DataReceived() function.
      13/12/2010 7:56:03 AM - UltraCID Debug - Waiting for the modem to respond with 'OK' for up to 2 seconds...
      13/12/2010 7:56:03 AM - UltraCID Debug - Entered ProcessReceived() function with a string [AT+GMM]
      13/12/2010 7:56:03 AM - UltraCID Debug - Exited Serial DataReceived() function.
      13/12/2010 7:56:05 AM - UltraCID Info - Database initialization complete. Ready to accept HomeSeer events into database.
      13/12/2010 7:56:05 AM - UltraCID Debug - Entered GetSetting() function.
      13/12/2010 7:56:05 AM - UltraCID Debug - Section: Settings, Key: Version, Value: 1.1.3809.11888
      13/12/2010 7:56:05 AM - UltraCID Debug - Entered Version() function.
      13/12/2010 7:56:05 AM - UltraCID Debug - Entered SaveSetting() subroutine.
      13/12/2010 7:56:05 AM - UltraCID Debug - Waited 2031 milliseconds for the command response.
      13/12/2010 7:56:05 AM - UltraCID Warning - No response/improper response from modem command 'AT+GMM'
      13/12/2010 7:56:05 AM - UltraCID Debug - Sending command: 'AT+VCID=1' to modem, attempt # 1
      13/12/2010 7:56:05 AM - UltraCID Debug - Entered SendToModem() function.
      13/12/2010 7:56:05 AM - UltraCID Debug - Sending AT+VCID=1 to modem serial port ...
      13/12/2010 7:56:05 AM - UltraCID Debug - Waiting for the modem to respond with 'OK' for up to 2 seconds...
      13/12/2010 7:56:05 AM - UltraCID Debug - Entered Serial DataReceived() function.
      13/12/2010 7:56:05 AM - UltraCID Debug - Entered ProcessReceived() function with a string [AT+VCID=1]
      13/12/2010 7:56:05 AM - UltraCID Debug - Exited Serial DataReceived() function.
      13/12/2010 7:56:05 AM - UltraCID Debug - Table tblCallerLog exists.
      13/12/2010 7:56:05 AM - UltraCID Debug - Table tblCallerDetails exists.
      13/12/2010 7:56:05 AM - UltraCID Debug - Section: DBSchema, Key: Version, Value: 1.0.1
      13/12/2010 7:56:05 AM - Error - Initializing interface: UltraCID->Could not initialize modem caller ID!
      13/12/2010 7:56:05 AM - Info - Finished initializing plug-in UltraCID
      13/12/2010 7:56:05 AM - Info - Initializing X10 Plug-in: X10 CM15AUSB On USB
      13/12/2010 7:56:05 AM - Info - Initializing Plug-in: X10 CM15AUSB
      13/12/2010 7:56:06 AM - CM15A - Initialization Successful.
      13/12/2010 7:56:06 AM - Info - Finished initializing X10 interface X10 CM15AUSB
      13/12/2010 7:56:06 AM - Info - Finished initializing infrared interface
      13/12/2010 7:56:07 AM - Info - Local IP address (subnet) is: 192.168.1.10 (255.255.255.0)
      13/12/2010 7:56:07 AM - Info - UPNP Discovery started
      13/12/2010 7:56:07 AM - Info - Web Server started on port 81
      13/12/2010 7:56:07 AM - UltraCID Debug - Waited 2031 milliseconds for the command response.
      13/12/2010 7:56:07 AM - UltraCID Warning - No response/improper response from modem command 'AT+VCID=1'
      13/12/2010 7:56:07 AM - UltraCID Debug - Sending command: 'AT+VCID=1' to modem, attempt # 2
      13/12/2010 7:56:07 AM - UltraCID Debug - Entered SendToModem() function.
      13/12/2010 7:56:07 AM - UltraCID Debug - Sending AT+VCID=1 to modem serial port ...
      13/12/2010 7:56:07 AM - UltraCID Debug - Waiting for the modem to respond with 'OK' for up to 2 seconds...
      13/12/2010 7:56:07 AM - UltraCID Debug - Entered Serial DataReceived() function.
      13/12/2010 7:56:07 AM - UltraCID Debug - Entered ProcessReceived() function with a string [AT+VCID=1]
      13/12/2010 7:56:07 AM - UltraCID Debug - Exited Serial DataReceived() function.
      13/12/2010 7:56:08 AM - Info - Web Server authorized local login successful from: 127.0.0.1 User: default
      13/12/2010 7:56:08 AM - Info - Creating ASP.NET application host...
      13/12/2010 7:56:08 AM - Media Player - Loaded 1500 tracks...
      13/12/2010 7:56:09 AM - UltraCID Debug - Waited 2046 milliseconds for the command response.
      13/12/2010 7:56:09 AM - UltraCID Warning - No response/improper response from modem command 'AT+VCID=1'
      13/12/2010 7:56:09 AM - UltraCID Debug - Sending command: 'AT+VCID=1' to modem, attempt # 3
      13/12/2010 7:56:09 AM - UltraCID Debug - Entered SendToModem() function.
      13/12/2010 7:56:09 AM - UltraCID Debug - Sending AT+VCID=1 to modem serial port ...
      13/12/2010 7:56:09 AM - UltraCID Debug - Entered Serial DataReceived() function.
      13/12/2010 7:56:09 AM - UltraCID Debug - Entered ProcessReceived() function with a string [AT+VCID=1]
      13/12/2010 7:56:09 AM - UltraCID Debug - Exited Serial DataReceived() function.
      13/12/2010 7:56:09 AM - UltraCID Debug - Waiting for the modem to respond with 'OK' for up to 2 seconds...
      13/12/2010 7:56:11 AM - Info - ASP.NET application host created
      13/12/2010 7:56:11 AM - Startup - Initializing text to speech
      13/12/2010 7:56:11 AM - UltraCID Debug - Waited 2015 milliseconds for the command response.
      13/12/2010 7:56:11 AM - UltraCID Warning - No response/improper response from modem command 'AT+VCID=1'
      13/12/2010 7:56:11 AM - Info - Listening for remote speaker connections on port 8742
      13/12/2010 7:56:11 AM - Startup - Start remoting
      13/12/2010 7:56:11 AM - Startup - Start event processing
      13/12/2010 7:56:11 AM - Info - This version of HomeSeer is registered.
      13/12/2010 7:56:11 AM - HSTouch Server - HomeSeer has started
      13/12/2010 7:56:11 AM - HSTouch Server - Server is enabled for unlimited connections.
      13/12/2010 7:56:11 AM - HSTouch Server - Server is enabled for iPhone/iPod HSTouch connections.
      13/12/2010 7:56:11 AM - HSTouch Server - Server is enabled for Android HSTouch connections.
      13/12/2010 7:56:11 AM - HSTouch Server - Waiting for music plugin Media Player to finish loading music library.
      13/12/2010 7:56:11 AM - Startup - Scripting is OK
      13/12/2010 7:56:11 AM - Info - Finished initializing scripting
      13/12/2010 7:56:11 AM - Startup - Starting scheduler
      13/12/2010 7:56:11 AM - Startup - Start up complete.
      13/12/2010 7:56:14 AM - Media Player - Loaded 2000 tracks...
      13/12/2010 7:56:20 AM - Media Player - Loaded 2500 tracks...
      13/12/2010 7:56:22 AM - Info - Speaker client connected from: 127.0.0.1
      13/12/2010 7:56:23 AM - Info - Speaker host added, Name: server IP address: 127.0.0.1
      13/12/2010 7:56:25 AM - Media Player - Loaded 3000 tracks...
      13/12/2010 7:56:29 AM - Media Player - Loaded 3500 tracks...
      13/12/2010 7:56:33 AM - Media Player - Loaded 4000 tracks...
      13/12/2010 7:56:35 AM - UltraCID Debug - Watchdog Timer database query returned 0 records.
      13/12/2010 7:56:35 AM - UltraCID Debug - Watchdog Timer indicates database is connected.
      13/12/2010 7:56:37 AM - Media Player - Loaded 4500 tracks...
      13/12/2010 7:56:41 AM - Media Player - Loaded 5000 tracks...
      13/12/2010 7:56:46 AM - Media Player - Loaded 5500 tracks...
      13/12/2010 7:56:50 AM - Media Player - Loaded 6000 tracks...
      13/12/2010 7:56:54 AM - Media Player - Loaded 6500 tracks...
      13/12/2010 7:56:58 AM - Media Player - Loaded 7000 tracks...
      13/12/2010 7:57:02 AM - Media Player - Loaded 7500 tracks...
      13/12/2010 7:57:05 AM - UltraCID Debug - Entered DBMaintenance_Elapsed() subroutine.
      13/12/2010 7:57:05 AM - UltraCID Debug - Watchdog Timer database query returned 0 records.
      13/12/2010 7:57:05 AM - UltraCID Debug - Watchdog Timer indicates database is connected.
      13/12/2010 7:57:05 AM - Media Player - Loaded 8000 tracks...
      13/12/2010 7:57:09 AM - Media Player - Loaded 8500 tracks...
      13/12/2010 7:57:10 AM - Media Player - Loaded 9000 tracks...
      13/12/2010 7:57:13 AM - Media Player - Loaded 9069 tracks total
      13/12/2010 7:57:13 AM - HSTouch Server - Server started on port 10200
      13/12/2010 7:57:35 AM - UltraCID Debug - Watchdog Timer database query returned 0 records.
      13/12/2010 7:57:35 AM - UltraCID Debug - Watchdog Timer indicates database is connected.
      13/12/2010 7:57:40 AM - HSTouch Server - Opening connection from:192.168.1.102/54085
      13/12/2010 7:58:05 AM - UltraCID Debug - Watchdog Timer database query returned 0 records.
      13/12/2010 7:58:05 AM - UltraCID Debug - Watchdog Timer indicates database is connected.
      13/12/2010 7:58:09 AM - Media Player - Finished loading Playlists
      13/12/2010 7:58:10 AM - Database Item - Saving Event Media Player Media Player Controls VR
      13/12/2010 7:58:12 AM - Database Item - Saving Event Media Player Media Player Controls VR
      13/12/2010 7:58:12 AM - Database Item - Saving Event Media Player Media Player Album VR
      13/12/2010 7:58:13 AM - Database Item - Saving Event Media Player Media Player Album VR
      13/12/2010 7:58:14 AM - Database Item - Saving Event Media Player Media Player Artist VR
      13/12/2010 7:58:15 AM - Database Item - Saving Event Media Player Media Player Artist VR
      13/12/2010 7:58:19 AM - Media Player - Library loading completed.
        I don't see your modem responding to any of the commands. In fact, it just looks like your modem is echoing the command is receives. If you connect to the modem using hyperterminal, what response do you get when you enter "ATQ0V1E0" (without the quotes)?
          Atq0v1e0
          ok
            and your modem is com3?
              Sure, it's in COM3, and I can get it work with many CID software.
                No idea??
                I just tried with an older U.S. Robotics PCI modem I had, this one's chipset is genuine 3Com and the newer I was using have a TI Chipset. BTW the older modem does not work either, I think the plugin got a serious incompatibilty issue with USR modems...
                I also tried to reinstall HS on another computer with a clean OS, same problem, the plugin simply don't work with USR modems.
                    Here what it does when disconnect/reconnect:
                    27/12/2010 12:22:34 AM - UltraCID Info - UltraCID - shutting down I/O ...
                    27/12/2010 12:22:34 AM - UltraCID Info - Database connection closed successfuly.
                    27/12/2010 12:22:40 AM - UltraCID Info - UltraCID - initializing I/O ...
                    27/12/2010 12:22:42 AM - UltraCID Warning - No response/improper response from modem command 'ATQ0V1E0'
                    27/12/2010 12:22:44 AM - UltraCID Warning - No response/improper response from modem command 'ATQ0V1E0'
                    27/12/2010 12:22:46 AM - UltraCID Warning - No response/improper response from modem command 'ATQ0V1E0'
                    27/12/2010 12:22:48 AM - UltraCID Warning - No response/improper response from modem command 'AT+GMM'
                    27/12/2010 12:22:50 AM - UltraCID Error - Failed to initialize caller ID. The command at+vcid=1 failed.
                    27/12/2010 12:22:50 AM - UltraCID Info - Database initialization complete. Ready to accept HomeSeer events into database.
                    27/12/2010 12:22:50 AM - UltraCID Warning - No response/improper response from modem command 'AT+GMM'
                    27/12/2010 12:22:52 AM - UltraCID Warning - No response/improper response from modem command 'AT+GMM'
                    27/12/2010 12:22:54 AM - UltraCID Warning - No response/improper response from modem command 'AT+VCID=1'
                    27/12/2010 12:22:56 AM - UltraCID Warning - No response/improper response from modem command 'AT+VCID=1'
                    27/12/2010 12:22:58 AM - UltraCID Warning - No response/improper response from modem command 'AT+VCID=1'
                    27/12/2010 12:23:00 AM - UltraCID Warning - No response/improper response from modem command 'AT+FCLASS=8'
                    27/12/2010 12:23:02 AM - UltraCID Warning - No response/improper response from modem command 'AT+FCLASS=8'
                    27/12/2010 12:23:04 AM - UltraCID Warning - No response/improper response from modem command 'AT+FCLASS=8'
                    27/12/2010 12:23:06 AM - UltraCID Warning - No response/improper response from modem command 'AT-STE=7'
                    27/12/2010 12:23:08 AM - UltraCID Warning - No response/improper response from modem command 'AT-STE=7'
                    27/12/2010 12:23:10 AM - UltraCID Warning - No response/improper response from modem command 'AT-STE=7'
                    I got two other modem yesterday and I've tried it with UltraCID, One is a HP LSI Soft modem and the second is a US Robotics soft modem 5660a. Both initialize well with UltraCID but I can't get any CID info. Ring, Ring Ring but no CID, even in a terminal window...
                    The first modem, the US Robotics PCI is a expensive hard modem and for now it is the only modem I tried that displays the CID info in Terminal or many other CID apps... It has no reason for not working in UltraCID... I really hope you'll find what is happening.
                      Caller ID on USR
                      Have you tried using AT#CID=1 instead of the default at+vcid=1? Most USR modems like # commands better.
