Default Speaker Client
    Ultra,
    I think I having a brain ****! I 'm trying to locate where to set the default speaker client. I can't seem to find it. If this feature is not implemented can you please do so? I have a speaker proxy that I use but I need to edit the default speaker client.
    Thanks!
    Originally posted by Sean Willoughby View Post
    Ultra,
    Thanks!
    Hello Sean. It looks like I'll need to add the ability to specify the speaker client. I assume you're looking for a text box to specify what speaker client should be used?
    Ultrajones
      Yes Sir. That is what I am looking for. I use the Sonos plugin and need to specify the client.
        I left you a post about this on your UltraWeather section. Just following up on this post as well.
        Thank You.
          UltraCID3 was my first plug-in that used triggers and actions. I had to re-write them last week so they matched my other HS3 plug-ins. Unfortunately, this means all events need to be re-saved or re-created. I'll be posting an update within a week or two.
          Ultrajones
            Thanks. It sure would be nice. Been waiting around for awhile. This plug-in (which I paid for) is useless for me at this time. Please fix soon.
              Sorry, but I am in the middle of some major trigger/action changes and cannot release the update until I am done. I expect to release it within a week.
              Ultrajones
                Any word yet?
                  Hello Sean. I decided to remove the e-mail and speak notification options from the UltraCID plug-in now that the plug-in has HomeSeer devices containing the last caller information. You can simply use the mechanisms built into HomeSeer to speak or e-mail the last caller details. Simply create a new event with the trigger "UltraCID3: Incoming Call" and select either "Send an E-mail" or "Speak Something". You'll then use the HomeSeer replacement variables to speak the caller name, number, ring count, etc.
                  I am packaging up the plug-in changes now (including the updates mentioned above) and will be posting it soon. I need to update the technology address to remove the ":" so the replacement variables are easier to use.
                  Let me know if you need event examples.
                  Ultrajones
