speaks wrong name
    speaks wrong name
    updated to 3.0.5144.35738, on first ring it speaks the previous caller on the second ring it will speak the correct caller. restarted hs3 and still having the issue, this was working fine in the previous versions.
    see below example
    Feb-11 3:34:09 PM TTS Speak (*:*):call from DAD
    Feb-11 3:34:09 PM Event Event Trigger "Telephone speak name"
    Feb-11 3:34:09 PM Informational Ring of existing call detected ...
    Feb-11 3:34:04 PM Informational Incoming call from DAD (401) xxx-xxxx
    Feb-11 3:34:03 PM TTS Speak (*:*):call from UNAVAILABLE
    Feb-11 3:34:03 PM Event Event Trigger "Telephone speak name"
    Feb-11 3:34:03 PM Informational New incoming call detected ...
    speaks wrong name
    see below example
    Hello. Caller CID isn't available until after the first ring. Don't use a caller ring action to speak the current caller. Switch the action to "UltraCID3: Incoming Caller" > "Announce Caller" instead.
    Sent from my iPad using Tapatalk HD
    Last edited by Ultrajones; February 12, 2014, 04:55 PM. Reason: Fixed Trigger Name
      I don't see the action announce caller in the events
        Sorry, the event trigger is "UltraCID3: Incoming Caller" and the "Select Caller" is "Announce Caller". This will ensure the event only triggers when you have the announce attribute set for the incoming caller. If you have the "Add Announce Attribute" set to True in options, then the plug-in will also announce first time callers.
        Ultrajones
          thought I had tired that and it did not speak any incoming calls, will try that again
          thanks
            those setting do work correctly, now sure why they did not the first time
            thanks
