Intermittent last caller attributes
    Hi,
    just thought I'd drop a post with regards to the occasional problem I'm seeing. I have a script that triggers on all calls, and then pulls in the data to make decisions on how to handle the call.
    99% of the time, works fine. Script extracts strings from the devices, no problem.
    Just occasionally, all but the last caller attributes are returned.
    The script literally does this:
    callergroup=hs.DeviceString(78)
    When it doesn't work, what is stamped in the log is:
    Jul-25 16:59:33	 	Info	string group is None
    Any ideas? The variable being set is the last of the caller ID devices (so kind of discounts it's running before all the devices get updated), and the script never fails to get the name and number. Also, it's not the string of the previous caller, just "None".
    Conversely, the last caller attributes device actually shows the correct attributes.
    I'll add a sleep into the script to give it an extra chance, just wondered if you could check the plugin side to see if anything could cause it?
    Yes, the caller attribute device was updated after the triggers were processed. I modified the HS3 version of the plug-in to update the attributes before checking the caller attribute triggers.
    Ultrajones
      Sorry, just catching up after vacation - thanks for looking into this and fixing
        Ultrajones
        Spoke too soon, had 2 calls today which didn't fire the events due to not having a valid string value:
        Aug-20 18:47:16	 	Info	string group is None
        Aug-20 14:10:17	 	Info	string group is None
        This is running version 3.0.5341.13686
