hi,
I have updated to the latest beta homeseer phone and for some reason hi phone is not detecting when i press the # key on the phone. I have tried everything i can think of. But to nothing.
I have done the test to check if hi phone is fine and it passes that. I have tried moving the 3 config file .(xml) again and again into the homeseer config dir and nothing. please help
here is a dump of device log
06/08/2002 18:06:25: Process Short Event: 63 Data: 0
06/08/2002 18:06:25: Handset off hook
06/08/2002 18:06:25: Notifying HS of event type: 9 DTMF:
06/08/2002 18:06:37: Process Short Event: 62 Data: 0
06/08/2002 18:06:37: Handset on hook
06/08/2002 18:06:37: Notifying HS of event type: 10 DTMF:
06/08/2002 18:07:36: Resetting line from Init (203)
06/08/2002 18:07:36: Resetting line: 1
06/08/2002 18:07:36: Stop Listening
06/08/2002 18:07:36: Enter OpenLine, line: 1 modem: Hi-Phone Device
06/08/2002 18:07:36: Enter WaitForCall...
06/08/2002 18:07:36: Enabling TTS
06/08/2002 18:07:36: Setting voice to: ATT DTNV 1.3 Mike
06/08/2002 18:07:36: Setting audio destination ID to: 5
06/08/2002 18:07:36: Enable TTS done
06/08/2002 18:07:36: Done Resetting line: 1
06/08/2002 18:07:49: Process Short Event: 63 Data: 0
06/08/2002 18:07:49: Handset off hook
06/08/2002 18:07:49: Notifying HS of event type: 9 DTMF:
06/08/2002 18:07:57: Process Short Event: 62 Data: 0
06/08/2002 18:07:57: Handset on hook
06/08/2002 18:07:57: Notifying HS of event type: 10 DTMF:
