Address book special announcement
    I get no announcement at all and the recording ends immediately, if I choose the "special announcement for this caller" in the address book Caller ID option.
    12/14/2003 4:35:43 PM: Start recording to: C:\HomeSeer\messages\4 35 43 PM_12-14-2003_U_Default__.wav ...
    12/14/2003 4:35:49 PM: Resetting line due to no pickup of call. Line: 1
    12/14/2003 4:35:49 PM: Resetting line due to no line pickup (113)
    If I don't select this option, the general greeting will be played and the message is recorded. I tried to test the announcement via the play button, but no sound came out of the sound card (maybe there is a way to test it over the phone?)
    I am using Way2call and HSPhone 2.0.146. Thanks for your help,
    picta
    AJ,
    Would you happen to have a "modem.log" file that covers the same time period as the shellbug log you posted? Way2Call cannot find an issue with the shellbug log, but I can tell them where the problem is if I have the modem.log.
    -Rich
    HomeSeer Technologies LLC
      After looking some more into the problem I found that the special announcement will be played over the phone if the box "Announce this caller" is not checked. Otherwise, the general greeting is played. Here is the modem log for both situations (first time the caller was announced via speakers, but no special greeting, the second time "Announce this caller" was unchecked). Thanks, picta
      8481.7 Call simulator active, generating ring, count: 1
      78481.72 Enter Speak: ringing
      78481.73 Exit Speak: ringing
      78481.77 Call simulator active, generating caller ID: Name: Gary Number: 7175555343
      78482.11 Enter Timerq
      78482.13 Unqueuing speak: ringing
      78482.16 Exit Timerq
      78483.23 Enter Raise Event sp_EndStream
      78483.27 Exit Raise Event sp_EndStream
      78484.16 Call simulator active, generating ring, count: 2
      78484.17 Enter Speak: ringing
      78484.2 Exit Speak: ringing
      78484.47 Enter Timerq
      78484.5 Unqueuing speak: ringing
      78484.53 Exit Timerq
      78484.72 Enter Answer
      78484.73 Ending call simulation
      78485.98 Enter Raise Event sp_EndStream
      78486.02 Exit Raise Event sp_EndStream
      78488.17 Enter StopPlayWave
      78488.19 Exit StopPlayWave
      78488.22 Enter PlayWaveFile: C:\HomeSeer\temp\_tempwav1_78488.wav
      78488.23 Exit PlayWaveFile: C:\HomeSeer\temp\_tempwav1_78488.wav
      78488.27 Enter Timerq
      78488.31 Exit Timerq
      78488.45 Enter ShortEvent Code: 40
      78488.48 DTMF: 4
      78488.5 Exit ShortEvent Code: 40
      78488.64 Enter ShortEvent Code: 5F
      78488.66 Exit ShortEvent Code: 5F
      78488.81 Enter EnableRecordToFile: C:\HomeSeer\messages\9 48 8 PM_12-15-2003_U_Default__.wav Format: 2
      78488.86 Exit EnableRecordToFile
      78493.23 Ending call simulation
      78493.33 Enter HangUp
      78493.47 Enter HandsetLine
      78493.5 Exit HandsetLine
      78493.53 Exit HangUp
      78493.55 Enter EndRecord
      78495.06 Exit EndRecord
      78495.81 Enter WaitForCall
      78495.84 Muting rings enabled
      78496.38 Exit WaitForCall
      78594.81 Enter WaitForCall
      78594.84 Muting rings enabled
      78595.38 Exit WaitForCall
      78595.41 Enter HandsetMonitoDTMF
      78595.55 Exit HandsetMonitoDTMF
      78595.56 Enter HandsetModem
      78596.11 Exit HandsetModem
      78597.41 Call simulator active, generating ring, count: 1
      78597.44 Enter Speak: ringing
      78597.45 Exit Speak: ringing
      78597.48 Call simulator active, generating caller ID: Name: Gary Number: 7175555343
      78597.86 Enter Timerq
      78597.88 Unqueuing speak: ringing
      78597.91 Exit Timerq
      78598.55 Enter Answer
      78598.58 Ending call simulation
      78599.48 Enter Raise Event sp_EndStream
      78599.52 Exit Raise Event sp_EndStream
      78600.17 Enter Speak: Hello Gary
      78600.2 Exit Speak: Hello Gary
      78600.23 Enter Timerq
      78600.25 Unqueuing speak: Hello Gary
      78600.28 Exit Timerq
      78601.75 Enter Raise Event sp_EndStream
      78601.78 Exit Raise Event sp_EndStream
      78603.3 Enter StopPlayWave
      78603.33 Exit StopPlayWave
      78603.36 Enter PlayWaveFile: C:\HomeSeer\temp\_tempwav1_78603.wav
      78603.38 Exit PlayWaveFile: C:\HomeSeer\temp\_tempwav1_78603.wav
      78603.41 Enter Timerq
      78603.45 Exit Timerq
      78603.97 Enter EnableRecordToFile: C:\HomeSeer\messages\9 50 3 PM_12-15-2003_U_Default_7175555343_Gary.wav Format: 2
      78604.02 Exit EnableRecordToFile
      78604.17 Ending call simulation
      78604.28 Enter HangUp
      78604.41 Enter HandsetLine
      78604.44 Exit HandsetLine
      78604.47 Exit HangUp
      78604.5 Enter EndRecord
      78606 Exit EndRecord
      78606.48 Enter WaitForCall
      78606.5 Muting rings enabled
      78607.05 Exit WaitForCall
