We are at the stage where the wired house phone line is only used for broadband internet, and our mobile phones are used for phone calls. The house phone is used very rarely. Since we are now getting a few spam calls to the house phone with fake caller Id, I wondered if there was a way to make a whitelist for HS3 to block them out ?
Whitelists and Hi-Phone
You can continuously add the scammer numbers to the HS Address Book and set them to hang up. This is a tedious and never ending task unfortunately.
Personally, I use a script run from an event which is triggerred when Caller ID becomes available.
The script hangs up on calls based on conditions like No CallerName except those with the local Area Code in the Caller Number (allows Cell phone Calls), Calls where the Caller Name, or partial name, is known to be a scammer, Calls with no CallerID at all, etc.
As a result, scam calls are caught before my internal phones ring.
You being in the UK I notice, my script probably wouldn't work for you as is anyway, but the idea could be a starting point for you.
Here's a post that details how to do what you want.
https://forums.homeseer.com/forum/le...-using-hsphone
It sends all calls from numbers not in your address book straight to voicemail. Then the IVR script for voicemail requires them to enter a "1" to leave a message. Since robocall computers don't understand the "dial 1 to leave a message", they just get hung up on!Fred
HomeSeer Pro 3.0.0.548, HS3Touch, Zwave 3.0.1.252, Envisalink DSC 3.0.0.40, WeatherXML, Z-stick, HS phone, Way2Call
Hi Fred,
Your existing script has kept those pesky spam callers with missing or short four digit numbers away for a few years now, but I recently started a proper contract for my mobile phone so I get unlimited calls with it. The house phone doesn't get used at all. I guess I could unplug it, but I do think it could be useful in an emergency.
My local area is suffering from a spate of pre-recorded spam calls (with fake local CID) saying things like "Your internet service will be terminated in 24 hours, unless you press button 1". I can only assume you get charged $$$'s if you do.
I have been adding the spammers one by one, but then I thought - whitelist ! I will take a look at that thread.
Thanks again,
TimWin 11 Pro | HS4 Pro | Z wave plug in with UZB1 | BLUSBUIRT 2.0.11.0 | RFXtrx433 | Blue Iris CCTV | VU+ 4k with motorised dish | Emby | Hi-Phone HS2 | ESP32 with WLED |
Thanks again,
TimFred
Originally posted by ITguyHS View Post
You could modify the IVR script slightly if you don't want to accept messages at all! Just remove the "press 1 to leave a message" portion as well as the "record prompt" and "record" portions. That way, IVR would answer and then just hang up! If you're using my "incoming call processing" script, you probably wouldn't need that any longer - just the IVR script would do it.
Just thinking... I'd like to have a bit of fun with the scam callers by giving them the runaround. IE. Having their calls answered with a list of options beginning with language selection...
For service in English, Press 1
For service in French, Press 2
For service in Mi’gmaw, Press 3
For Service in German, Press 4
For Service in Spanish, Press 5
And so On to
For more options, press 9
Then give them a whole new list of options until they get so frustrated they hang up. It's their dime afterall.
When they do make a selection, tell them "Your selection was not understood", then repeat the whole thing.Real courage is not securing your Wi-Fi network.
Originally posted by Wadenut View PostJust thinking... I'd like to have a bit of fun with the scam callers by giving them the runaround. IE. Having their calls answered with a list of options beginning with language selection...
And so On to
When they do make a selection, tell them "Your selection was not understood", then repeat the whole thing.Fred
I present unknown (not on white list) callers with the following options.
Press one to leave a message
Press two if you would like for us to take a poll or survey
Press three if you are a charity
Press four if you are some other exception to the do not call list
Press five if you are from microsoft and wish to help us with a computer virus
Press six if you are some other scam
Press seven if you would like to hear a neat song about answering machines
I actually had one caller select option 6, which results in the message: I appreciate your honesty about being a scammer. Your number will be added to our blocked list. Be aware that it may take a few days. Goodbye.
I do have a blocked number list that just gets a hangup.
