When the phone handset is lifted events stopped working
    Hi,
    i have an event that turns off the music in my home office when i lift the handset, and i noticed that it stopped working in 2016, has anyone else had issues with this event trigger?
    The "When Caller ID information is available" trigger is working without issue.
    any ideas?
    thanks
    Raptor
    HS3 Pro on Windows 8 64bit
    53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
    Check out my electronics blog here:
    https://www.facebook.com/RaptorsIrrationalInventions
    Mine was working fine until I got rid of my landline a year ago. Did you try deleting the trigger and re-building it? The event trigger I used was:
    IF When the phone handset is lifted on line 487-7908 (1)
      Also, are you sure the phones are all routed through the Way2Call, ie plugged into the Way2Call line out, not just plugged into the same jack. Line in and out reversed maybe?
