I got a way2call (got lucky and got one of the ebay UK deal ones) and have it connected. All of the W2C hardware tests passed with flying colors. I have one standard (not cordless) phone connected to the W2C's phone jack. I got it set up in HS. I have my Windows audio for record and playback set to my default sound card. When I try to use W2C to issue voice commands (in this case "Turn den light on") here's what I get in the log:
6/4/2007 4:55:06 PM ~!~HSPhone~!~Off Hook
6/4/2007 4:55:06 PM ~!~HSPhone~!~Waiting for Command Key (#) ...
6/4/2007 4:55:08 PM ~!~HSPhone~!~DTMF: #
6/4/2007 4:55:08 PM ~!~HSPhone~!~Connected line: Default Line
6/4/2007 4:55:08 PM ~!~Info~!~Read 403 lines from IVR file C:\Program Files\HomeSeer 2\ivr\internal.txt
6/4/2007 4:55:09 PM ~!~Info~!~Loading internal VR
6/4/2007 4:55:09 PM ~!~HSPhone~!~Building HomeSeer voice commands: 60909.203125
6/4/2007 4:55:09 PM ~!~HSPhone~!~Finished build HomeSeer voice commands: 60909.359375
6/4/2007 4:55:09 PM ~!~HSPhone~!~Adding voice command: +yes ?please
6/4/2007 4:55:09 PM ~!~HSPhone~!~Adding voice command: +no ?thank ?you
6/4/2007 4:55:09 PM ~!~HSPhone~!~Adding voice command: good bye
6/4/2007 4:55:09 PM ~!~HSPhone~!~Adding voice command: messages
6/4/2007 4:55:09 PM ~!~HSPhone~!~Adding voice command: +help
6/4/2007 4:55:09 PM ~!~HSPhone~!~Adding voice command: leave a message
6/4/2007 4:55:09 PM ~!~Info~!~Finished loading internal VR
6/4/2007 4:55:09 PM ~!~HSPhone~!~StartListening
6/4/2007 4:55:10 PM ~!~HSPhone~!~Line: Default Line Speak: hello sire
6/4/2007 4:55:10 PM ~!~HSPhone~!~Disable Listen
6/4/2007 4:55:16 PM ~!~HSPhone~!~Heard: dial four eight one
6/4/2007 4:55:16 PM ~!~HSPhone~!~Heard (parsed): dial 4 8 1
6/4/2007 4:55:17 PM ~!~HSPhone~!~Disable Listen
6/4/2007 4:55:17 PM ~!~HSPhone~!~Line: Default Line Speak: Shall I dial four eight one
6/4/2007 4:55:23 PM ~!~HSPhone~!~Heard: no
6/4/2007 4:55:23 PM ~!~HSPhone~!~Heard (parsed): no
I say "Turn den light on" and it hears it as "dial 4 8 1". Looks like VR doesn't work very well. Also I do not hear the "yes sire" in response to my pressing #, only a beep.
Any ideas what might be wrong?
