Help! We had a bad storm here and I had to shut everything down quick. Now my Way2Call is not recognized on my HS Server. I have tried everything listed here. I know the unit is OK, because I installed it on my laptop and it showed right up. Does anyone know where in the registry I can edit/delete the settings and try to get it back? Thanks,
Way2Call Troubles
You may be quicker to delete the phone.ini file from the config directory and just re-install Way2Call.
I suppose you could try renaming the ini file, creating a new one then pasting the old one back, but I doubt it.
If after a fresh install of HSP,s ini it still does not work then I would start looking to see if the PC has been damaged in any way.sigpic
Shut down the computer, unplug the W2C USB cable, start the computer back up without HomeSeer running, then plug in the USB cable.
Does your harddrive light start blinking rapidly for a few, does Windows say New Hardware Found?
I'd do a screenshot of my Device Manager but my VNC is fighting me.
With the W2C unplugged from the USB port have you tried re-installing the W2C USB drivers?
~Bill
