Hi,
Does anyone know if HS supports two way2calls at once? There is clearly the option for different lines in the Phone setup tab and the HS log shows HS as seeing both devices, but the second way2call doesn't appear within the drop down 'line' box to allow it to be set up.
The way2call test program sees them both and can control them.
Jon
Jon
