Hi Chaps,
Has anybody got a Way2Call working with a SIP line?
My current setup is normal analogue line -> Way2Call -> Analogue DECT Phones......works great.
But I would like to use a SIP line for this instead of the analogue line but when I plug the Way2Call into the SIP line it just constantly tries to grab the line, log below
09/02/2009 14:03:57 - Info - Internal answer is disabled, ignoring off-hook
09/02/2009 14:03:58 - HSPhone - On Hook
09/02/2009 14:03:58 - Info - Muting rings enabled
09/02/2009 14:03:58 - HSPhone - Off Hook
09/02/2009 14:03:58 - Info - Internal answer is disabled, ignoring off-hook
09/02/2009 14:03:59 - HSPhone - On Hook
09/02/2009 14:03:59 - Info - Muting rings enabled
09/02/2009 14:03:59 - HSPhone - Off Hook
09/02/2009 14:03:59 - Info - Internal answer is disabled, ignoring off-hook
09/02/2009 14:04:00 - HSPhone - On Hook
09/02/2009 14:04:00 - Info - Muting rings enabled
09/02/2009 14:04:00 - HSPhone - Off Hook
But when I plug the Analogue DECT phones directly into the SIP line all works?
Is there a setting in HS I should be changing or perhaps a new firmware/driver for the Way2Call?
FYI - SIP line is off my router (DrayTek 2820) basically provides two analogue lines if registered.
