I am using Homeseer 2.3.0.19 with way2call, hai, insteon, gc100, and cm11a x10. My way2call system worked fine for about a month, then it quit detecting dtmf tones and the volume of the recorded messages from callers is so low I can barely hear them.
I tested the way2call with the way2call test software, and it detects all buttons.
I have repaired homeseer, and removed and installed the way2call several times. still no help.
I would appreciate some help. If my way2call is defective, I need to send it back, but I want to make sure it is not homeseer first.
Thank you.
Thank you.
