Anyone using the Way2Call modem with Windows Home Server?
The reason I ask is I am having some trouble accessing the modem with anything other than HS.
When I first install the drivers, the TAPI setup that gets installed can see the modem. If I reboot, it goes away, however, HS seems to be able to use the modem. Does HS someone take exclusive ownership of the modem?
I need YAC to also access the mode to provide CID/call info to another application and I can't seem to get it to work. Any thoughts?
EDIT: BTW, I am using the most recent drivers and firmware for the W2C.
