After 6 years, I moved my HS server ti a bew home - everything works perfect... Except...
I am getting the following errors on startup of Way2Call in HS:
I have the original W2C disk, intalled the drivers and did their diagnostics and everything checked out. Worked fine on the old systen. I deleted the line and added it again too - same errors.
Win XP/64 is the new system, XP was the old...
4/22/10 5:37:42 PM ~!~HSPhone~!~Resetting line: 269-XXX-XXXX 4/22/10 5:37:44 PM ~!~Error~!~Initializing audio play/record support: Unable to cast COM object of type 'hsrecord2.hsrecordplayClass' to interface type 'hsrecord2._hsrecordplay'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{C9B8687D-F497-4520-98A0-ED20C8634473}' failed due to the following error: Error loading type library/DLL. (Exception from HRESULT: 0x80029C4A (TYPE_E_CANTLOADLIBRARY)). 4/22/10 5:37:44 PM ~!~HSPhone~!~Error initializing Hi-Phone driver, possible corrupt or missing drivers, or Hi-Phone is not plugged in or powered on. 4/22/10 5:37:46 PM ~!~HSPhone~!~Calling hangup for line: 269-XXX-XXXX
