Way2Call + Lantronix USB-Ethernet
    Can the Way2Call modem be connected to the Lantronix USB-Ethernet and a wireless access point? The Hometroller isn't near a phone jack. I'm using Ethernet over power lines anyway so a phone jack using power lines probably won't work. Any other suggestions?
    The W2C box didn't work for me using the DigiAnywhere USB-Ethernet box. HSPro did recognize the W2C box; it didn't pass audio though.
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X
    HS4 Pro - V4.1.7.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
    HS4 Lite -
      I found something in my "junk" pile that I might try and theoretically could work.
      It is an old Panasonic wireless data link. Many years ago (before 802.XX wireless) it provided me with a means of mobility via my dial up access.
      It is the Panasonic Model KX-TCL100-B.
      When used it disconnects the telephone port if I recall.
      - Pete
      Auto mator
      HS4 Lite -
