W2C box, HSPro .72 and Windows 7 Ultimate
    I recently upgraded HSPro to Windows 7 Ultimate. I have just recently installed newest W2C drivers to the box. I have not touched the FW of the W2C box since purchase a few years back.
    When HSPro .72 is booting I see the following:
    11/23/2010 6:09:25 AM HSPhone HomeSeer Phone Web Interface initializing.
    11/23/2010 6:09:25 AM HSPhone Adding phone line 1, Name: Line-1, Modem: Way2Call Hi-Phone Desktop
    11/23/2010 6:09:25 AM Phone Line 1 Initializing Hi-Phone device...
    11/23/2010 6:09:29 AM HSPhone Muting rings disabled
    11/23/2010 6:09:31 AM Startup Checking for pending updates to be installed...
    11/23/2010 6:09:31 AM Startup Restoring Device Status...
    11/23/2010 6:09:32 AM Startup Checking for available plug-ins
    11/23/2010 6:09:32 AM HSPhone Wave OUT id: 1
    11/23/2010 6:09:33 AM HSPhone Found Hi-Phone audio device: Speakers (Hi-Phone Desktop USB)
    11/23/2010 6:09:34 AM HSPhone Wave IN id: 0
    11/23/2010 6:09:34 AM HSPhone Voice Recognition Language ID: 1033
    11/23/2010 6:09:35 AM Plug-In Found plug-in: BLOutgoingCalls, version: 1.0.13.0
    11/23/2010 6:09:35 AM HSPhone Error in Hi-Phone InitVR: (0), Exception from HRESULT: 0x80045002
    11/23/2010 6:09:35 AM HSPhone On Windows 7, ignore error 80045002. Use the Speech control panel, advanced view, to set the audio input to the Hi-Phone USB
    I do not utilize HSPhone with VR nor do I utilize VR for anything related to HSPro.
    Initially I didn't see a Wave in or out id. I copied the W2C DLL over to the HS directory and now see it. I've also installed SAPI 5.1 but have no idea if W7 is utilizing it.
    I have set the Hi-Phone USB audio input in the speech control panel to either microphone or aux input. Doing this has not changed the error message on HS bootup.
    Any suggestions?
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X
    HS4 Pro - V4.1.7.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
    HS4 Lite -
    Just ignore it.
    Other pople have this too: http://board.homeseer.com/showthread.php?t=143950
    Jon
      Thanks Jon.
      Yes read thru a bunch of threads relating to said issue except for the one you posted and I guess the A.D.D. in me doesn't want to see any errors on bootup of HSPro.
      - Pete
      Auto mator
      HS4 Lite -
