Anyone have a W2C script that takes the incoming CID and reformats it? Basically want to put first name then last name on the CID? I know SnevlCID does this but just looking for something simple that uses the HSP phonebook.
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
