Send email on ring with caller id info
    Hi not sure if this has been asked before but i am trying to send an email with the caller id info when someone calls the house.
    i can't work out how to do it and cant find the solution anywhere...
    any ideas?
    Raptor
    HS3 Pro on Windows 8 64bit
    53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
    Check out my electronics blog here:
    https://www.facebook.com/RaptorsIrrationalInventions
    It's probably more than you are looking for, but my SnevlCID package does it. You can set it up to work directly with HSPhone. I have it send me a text message (you can separately do an email as well) each time a call comes in. The whole package is probably overkill for just doing what you want, but if you don't come up with some other way, it would do it.
    Steve
      Thanks Steve, i will search for it
        If you are using HomeSeer Phone then select a trigger type of phone and then in the On CallerID Available. Then in the actions select email
        -Rupp
          I forgot about the CallerID available trigger. That does sound like the easiest way to do what he wants.
          Steve
            Hi,
            the issue here is i can't get the email to show the caller id info from the script.
            it is sending me the email just withouth the caller id/
            Raptor
              Raptor,
              I hadn't noticed your follow-up post, so assumed you were good to go. Sorry for abandoning you.
              A short script should do you:
              PHP Code:
              Sub Main(ByVal parms as Object)
              Dim num as String hsp.CIDnumber(1)
              Dim name as String hsp.CIDname(1)
              Dim msg as String "A call was received from " name ", at number " num
                      Dim s_to
              as String ""
              Dim s_from as String "insert from address here>"
              hs.SendEmail(s_to,s_from,"Phone call",msg)
              End Sub
              Create an event that is triggered on "CID available" as Rupp suggested, and use this script (save it as a .VB file) as the action.
              Make sure you put in the right TO email address, and the FROM needs to be a legit email address. Of course, you need to have set up email in the HS config.
              Steve
