pci modem error in startup
    so I have the way2call interface working, when homeseer boots I get this..
    it all still works but I see no way to delete this modem.
    any ideas?
    8/16/2016 3:13:49 PM ~!~Error~!~Unable to determine COM port of modem: HomeSeer PCI Voice Modem V2 Try selecting a different modem, this one may not exist in the system.
    8/16/2016 3:13:49 PM ~!~Error~!~Unable to find COM port for PCI modem
    8/16/2016 3:13:49 PM ~!~Error~!~Program error in StopSpeaking: Object reference not set to an instance of an object.Startup Complete, 3 errors detected, check the log for more information.
    no replies? is there no homeseer support here?
    I seem to post these and unless another user replies I get nothing, is there no homeseer support for paid long time users?
    any ideas?
      The bulletin board is intended as a user forum, not an official support forum. If you want HS support, email them at support@homeseer.com, call them or you can attempt to submit a bug report or enhancement request through bugzilla.
      Cheers
      Al
        Regarding your problem, it seems like you have some extra settings in your hsphone.ini file. Shut down HS and edit that file to remove the line info for the pci modem. Alternately, just delete the file and start HS again and reconfigure manually for the way2call. I had similar issues when I recently migrated from a pci modem to the way2call.
        Cheers
        Al
