AKHeatmiserNeo Plugin for Heatmiser (UK) NeoHub
This is a sticky topic.
    My plugins:
    Click image for larger version  Name:	ikea_64.png Views:	0 Size:	2.1 KB ID:	1421180​​
    AK IKEA
    Click image for larger version  Name:	Square64.jpg Views:	0 Size:	2.8 KB ID:	1421181​​
    AKSquare
    Click image for larger version  Name:	Bond64.png Views:	0 Size:	5.1 KB ID:	1421176​​
    AKBond
    Click image for larger version  Name:	Sonoff64.png Views:	0 Size:	5.6 KB ID:	1421182​​
    AKSonoff
    Click image for larger version  Name:	Shelly64.png Views:	0 Size:	6.5 KB ID:	1421184​​
    AKShelly
    Click image for larger version  Name:	gates  - 3.jpg Views:	0 Size:	93.7 KB ID:	1423325
    AKRemootio
    Click image for larger version  Name:	AKEnphaseEnvoy64.png Views:	0 Size:	8.7 KB ID:	1421179​​
    AKEnphaseEnvoy
    Click image for larger version  Name:	AKGoogleCast64.png Views:	0 Size:	1.5 KB ID:	1421178​​
    AKGoogleCast
    Click image for larger version  Name:	AKGoogleCalendar64.png Views:	0 Size:	3.4 KB ID:	1421177​​
    AKGoogleCalendar
    Click image for larger version  Name:	AKSmartDevice64.png Views:	0 Size:	6.0 KB ID:	1421183​​
    AKSmartDevice
    Click image for larger version  Name:	AKHeatmiserNeo64.jpg Views:	0 Size:	2.1 KB ID:	1421185​​
    AKHeatmiserNeo
    Click image for larger version  Name:	AKTracdown500 - New.png Views:	0 Size:	300.3 KB ID:	1423326
    AKTracdown
    HomeSeer plugin for Heatmiser Neo line of products. Based on latest JSON protocol specification REV2.601 which replaced older obsolete communication protocol.
    Click image for larger version  Name:	AKHeatmiserNeo500.jpg Views:	7 Size:	27.3 KB ID:	1421186 https://shop.homeseer.com/products/a...lug-in-for-hs3
    • To minimise number of HS devices created - NeoHub and NeoStat root devices used to control system modes
    • Whole system modes: Normal, Away, Holiday
    • Individual Thermostat mode: Standby, Normal, Away, Hold
    • Current Temperature, Setpoint, Hold Temperature, Standby Temperature HS devices
    • NeoStat Scheduler (Profiles) management
    • NeoStat settings: Switching Differential, Switching Delay, User Limit, Max Preheat Duration, etc.
    • NeoHub settings: Polling Frequency, Units, Program Mode (One Day, 5/2 Days, 7 Days), Time Zone, etc.
    • Automatic NeoHub time synchronisation with computer clock
    • Recent Temperature chart (last 24 hrs)
    • Insights into complete NeoHub and NeoStats configuration settings
    Installation and Configuration
    After installing the plugin the NeoHub root device is created:
    Click image for larger version  Name:	NeouHub device.PNG Views:	1 Size:	42.9 KB ID:	1294402
    Go to the device configuration and set the hub IP address:
Name:	NeouHub config.PNG
    When plugin is connected to NeoHub - it creates devices for each NeoStat configured in the system:
    Click image for larger version  Name:	NeouStat device.PNG Views:	1 Size:	188.3 KB ID:	1294405
    To configure individual NeoStat settings and schedules go to the NeoStatRoot device configuration:
    Note: for NeoHub and Neostat settings description refer to the user manual which comes with your devices
    Click image for larger version  Name:	NeouStat config.PNG Views:	1 Size:	171.4 KB ID:	1294406
      Version 1.0.0.7 Includes Recent Temperature charts (last 24 hrs), which are also accessible via http://192.168.1.81/AKHeatmiserNeo/temps.png
      Click image for larger version  Name:	NeouHub config with chart.PNG Views:	68 Size:	261.1 KB ID:	1299918
        Ver 3.0.0.20 - added NeoAir and NeoPlug support.
          Ver 3.0.0.23 - Improvements in HSMobile thermostat controls display
            Ver 3.0.0.27 (in BETA until approved by HST) fixed Hold temperature going to 0; made possible disabling flashing the thermostat screen (int NeoHub Config page)
            Note: be aware - in preparation for HS4 migration the thermostat root address may change (from ver .24) - so you may end-up with duplicated thermostat devices, please verify.
              Ver 3.0.0.30 (in BETA until approved by HST) - Fixed Hub time sync with computer
                Ver 3.0.0.31 - Added error handling in NeoHub Update function.
