AKHeatmiserNeo Plugin feature requests
This is a sticky topic.
    #46
    If NeoPlug only have On/Off controls - I can use the root device, there's no need to create two HS devices.
      #47
      Here a screen shot of a timer profile from the neo app
      aan=on / uit=off (translation is stille in beta?)
      User manual is no more then a quick start guide
        #48
        There's no images...
          #49
Name:
ID:	1348639 Click image for larger version
Name:
            #50
            Thank you JanL
              #51
              Another request: Better functionality in the Homeseer (android) App.
              Ok, finally I managed to work out the setup to work in HSMobile - took me 1.5 months trying Rich to sort out this simple problem. Really frustrated.
              Anyways, ver 3.0.0.23 in BETA section. Red is the heating setpoint, blue is the standby temperature.
              I still need to find out how to display the controls for the mode i.e. Normal/Standby/Away/Hold. But it's another story...
                #52
                Forgot to mention - you probably need to recreate the devices to get it working.
                  #53
                  Is there any way of stopping the thermostats flashing when they have had a change made to them. It only seems to be when using this plugin. Initially it was handy but now its a little annoying as I have 10 in my home. Thanks
                    #54
                    I think it's cute too. But if it's annoying - I'll have to make it configurable.
                      #55
                      Ver 3.0.0.26 (in BETA until approved by HST) - added "Flash" checkbox on NeoHub config page
                        #56
                        It's still flashing when plugin starts, so you can see that HS was restated
                          #57
                          That's absolutely perfect. Thank you for the quick reply and solution. I wish I could code better. It's amazing that you can add that so quickly. Nice one.
                            #58
                            No problem. Probably would be even better to make it configurable per thermostat, but cbf...
                              #59
                              Unfortunately on further inspection that beta seems to have killed the events. I can still select the modes in the devices tab and the thermostats do not flash so that part is working. However the events actions do not run. I wonder if by installing the beta although the devices seem to be the same they may need to be completely re indexed in the events. I'll have a play later.
                                #60
                                In the logs I have seen these errors...
                                The update shouldn't affect the events. I'll check.
                                The yellow (warnings) are not error - just an info, every time the plugin starts.
                                There's an error (red) from NeoHub, which is probably affecting the event action, but:
                                1. I need to know what's causing the error, i.e. can you reproduce it?
                                2. The error is about CANCEL_HGROUP - which means you cancel HOLD?
                                3. Please create a new thread for the error - don't mess up this one.
