Hi.
I have moved home and purchased a new heatmiser neo device that is a thermostat and hot water timer in one. The plugin recognises it as 2 seperate devices however some of the functions on the timer do not work.
What I am trying to fix is this. When I select hold on the timer device I would like the hot water (timer) to hold for an hour. I have changed the time timer to 1 hour but this doesn't work.
Instead I have noticed that if it select a random temperature of say 30 degrees for the hold temp the TIMER will say hold (for 23.59) which is the hold setting for the thermostat. So it does work but not as intended.
I hope this makes sense. It's slightly odd behaviour.
