before I pull the trigger on purchasing I am wondering if this plug in supports the 8800 I have 8 zones they go through the 8819 Distribution Panel talk with rs485 protocol thanks
Support for the aprilaire 8800
I know you can control more than one heat or cooling source at least with the 8840 because I have one that is set up like that. I have two heating sources and one cooling on the same thermostat. One heat source is a zoning valve for a hot water coil in my furniture and the second heat source, or stage as it is labeled in aprilaire, is the gas portion of my furnace. The water coil is primary and gas is secondary. Works wonderfully. Now in a zoned setup though that is a whole nother beast. You should call into aprilaire support and they can go over your options. They are really good.
Guest
